-   Tools (http://www.diychatroom.com/f29/)
-   -   oil and gas mixture " used weed wacker" (http://www.diychatroom.com/f29/oil-gas-mixture-used-weed-wacker-146109/)
oldrivers 06-05-2012 05:20 PM
I picked up an older weed wacker at a pawn shop has no instructions .. was curious what a good mix ratio should be , i always just sort of guessed but would like to get a better idea what it should be or what a safe ratio would be.
joecaption 06-05-2012 05:22 PM
I have three and and several chain saws and they all take 50:1.
http://www.ehow.com/way_5990608_do-g...-trimmer_.html
oldrivers 06-05-2012 05:28 PM
ok, i was about 30-1 and was smoking a little there. thanks .
ratherbefishing 06-05-2012 06:40 PM
If you use 50/1, make sure you're using an oil that will support that ratio. A lot of popular power eqipment oils are formulated for 32/1. Most of the 4oz bottles sold at the box stores add to a gallon of gas.
Who manufactured the weed wacker?
oldrivers 06-05-2012 10:33 PM
its a homelite name but not sure if thats the manufacturer.
joecaption 06-05-2012 10:38 PM
Are you 100% sure it's a 2 stoke. I own a Homelite that's a 4 stroke.
Simple to check, look for an oil dip stick.
tuchodi 06-06-2012 09:29 AM
The mixing ratio is more about the oil than the motor you are using it in. Get a good quality oil that can mix at 50/1 and use that. I have switched over to Synthetic oil and I have noticed an incredible difference in how much easier they start and runs smother both at full load and at an idle.
