Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-11-2012, 06:16 PM   #1
Not what it's meant for
Has anyone ever put an abrasive wheel in a 10" miter saw and used it to cut steel?
Or do I have to spring for 14" chop saw?
Kenlguy is offline   Reply With Quote
Old 04-11-2012, 06:42 PM   #2
Rpm on most mitre saws are too high. I would go for a metal chop saw. I bought one with a carbide blade and I have gone 6 years on I e blade.
robs660 is offline   Reply With Quote
Old 04-11-2012, 07:30 PM   #3
What is it your trying to cut? And how often are you going to be doing it?
I for one would never want rusty metal chips all over my mitre saw.
Old 04-11-2012, 09:28 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
what are you trying to cut.. if its just for rebar use a mini grinder and a zip wheel
woodworkbykirk is offline   Reply With Quote
Old 04-11-2012, 11:45 PM   #5
Mostly 1/2" to 1" metal electrical conduit for a welded "art" project. I've got an older off brand mitre saw that I don't use anymore because it's not that accurate so I don't care if I ruin it or not. I was just wondering if it would work for about two dozen cuts that have to be a little more precise than an end saw.
Old 04-12-2012, 01:41 PM   #6
raylo32's Avatar
A corded or cordless angle grinder with a cut-off wheel would do the trick.
raylo32 is offline   Reply With Quote
Old 04-15-2012, 09:13 PM   #7
i did it, and it worked fine. and i cut some pretty heavy stuff on it. for what you want to do, no issues at all.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Toilet Drain Gap Issue Trial and Error Plumbing 14 08-16-2012 11:16 PM
Using Hardi siding as form for concrete patio TCS-Austin Building & Construction 13 08-14-2011 11:35 AM
leak that defies physics fpcottage Plumbing 12 07-15-2011 02:27 PM
Bathroom paint/primer Termite Painting 11 07-02-2008 03:28 AM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
