Nice Small Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 06:16 AM   #1
DIY staff
Rewards Points: 7,174
Nice small compressor
My back is not what it once was---so I like to keep a small compressor in the truck and only use the double tank for serious framing---
Shop Kobalt 1.5-HP 3-Gallon 155-PSI Electric Air Compressor at Lowes.com
I bought the Kobalt one in the link above---so far so good---at 2.6 CFM it will keep up with most tools,including a framing gun on a small project--
Every important part is enclosed within the cage--no parts to get smashed up in the truck----
My assistant liked it so much that he has one now----let's hope it holds up well---sure is the best design I've seen for transporting in a crowded truck.---Mike-----
Old 09-17-2013, 06:37 AM   #2
kwikfishron's Avatar
Rewards Points: 580
That would be a nice feature...I've broke the brass nipple going into the tank of me little Senco many times. Inexpensive part but can mess up a good day real fast when it happens. I carry spares now.
kwikfishron is online now   Reply With Quote
Old 09-17-2013, 06:57 AM   #3
Rewards Points: 13,712
A couple issues you "may" run into is finding repair parts and the short time between cycles because of the smaller storage tank.
Old 09-17-2013, 06:58 AM   #4
DIY staff
I'll let you know how these hold up---so far I really like it----
The last one I owned worked---but the air cleaner and gauges and rubber feet were either missing or smashed within the first month.
Old 09-17-2013, 07:03 AM   #5
DIY staff
I've had several 'baby' compressors over the last 10 years---so I am used to the short comings of a little compressor----(Senco was a favorite)
waiting for them to return to pressure---I do have a big compressor for serious work---but for a one man trim job or building one small partition, I prefer to save my back and use the 'baby'
Old 09-17-2013, 09:45 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
With 1 1/2 HP it should do what you want it to do on small jobs. I use to have an Excalibur framing compressor, (just one among many) that had to be the heaviest sucker for a portable compressor I have ever seen, took two guys to carry when it couldn't roll. I left it in the van as much as possible.
I still have my Senco, it is still running good after 18 years. If there had been a small compressor like yours, back then I sure would have tried it.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-17-2013, 06:02 PM   #7
DIY staff
They are a real back saver---I just don't need a big boy most of the time---and at 2.5 CFM @90 this one keeps up ----I'll be putting up some trim tomorrow with my assistant---I might bring the big boy so I can run two hoses---one for the brad gun--one for the finish gun.
I need to rig up something for my helpers compressor---we both like two guns----that little compressor only has one outlet---
Old 09-17-2013, 07:35 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
Mike you could pick up a couple of these manifolds, I had 3 or 4 of them so we could hook up several hoses at a time.
Jim
Old 09-17-2013, 08:39 PM   #9
DIY staff
Handy---I made up my own with a T-fitting long ago--nice to see that a premade one is available---
Old 09-17-2013, 08:49 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
I hadn't thought about that but it would sure work.
Jim
Old 09-18-2013, 06:23 AM   #11
Rewards Points: 5,974
I did the same thing a short time ago, got tired of hauling out the double tank, I went with a pancake wish I had seen this one.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
BigJim (09-18-2013), oh'mike (09-18-2013)
Old 09-18-2013, 07:40 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
The pan cake type made me think of what a fellow I knew did to his compressor. The relief valve was leaking on his compressor so he stopped it up some way, the thing blew up and busted a big hole in the wall and rusty water everywhere. Could have been him instead of the wall.
Jim
Old 09-18-2013, 01:47 PM   #13
I got one of the little sencos not long ago:
http://www.senco.com/CompressorDetails.aspx?k=PC1010
I love the quiet operation of this thing. It seems fine for trim nails and staples, but would not keep up with a rapid-fire framing nailer, I don't believe.
I sure do like the kobalt idea of the roll cage. I feel I have to be pretty careful with the senco to keep from hitting a fragile component.
oberkc is offline   Reply With Quote
Old 09-18-2013, 07:27 PM   #14
DIY staff
I had a little Senco similar to that----It was my first baby and I liked it---but when it wore out--the parts cost to much---so it was junked. I got plenty of use out of it--so I was not disappointed---
Old 09-19-2013, 03:15 PM   #15
Young Bachelor
CTSNicholas's Avatar
Rewards Points: 417
I have heard about that model of Senco compressor having poor insulation on some internal wires. Apparently there is a grommet that manages to strip the insulation back making the compressor more or less a hot wire to touch if not touching it with gloves or by the rubber handle.
It may be worth your interest to check it out online or check the grommet where wires go into a connection box to be crimped.
CTSNicholas is offline   Reply With Quote
The Following User Says Thank You to CTSNicholas For This Useful Post:
oberkc (09-20-2013)
Hard start for compressor bob22 HVAC 3 01-13-2013 07:54 PM
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
Issue with compressor unit boast HVAC 2 08-29-2012 10:04 PM
Do I really need a new compressor, or am I about to be ripped off? mrgadfly HVAC 8 07-02-2011 05:01 PM
Small air compressor recommendation Quoheleth Tools 6 08-01-2009 08:53 PM
