Ni-Cad Storage? - Tools - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 07:38 AM   #1
Rewards Points: 502
Ni-Cad storage?
I have a Cordless Senco collated screw gun that I don't use constantly, and is now out of production. To get the most years out of the batteries, what is the best way to store them? Does temperature matter?
forresth is offline   Reply With Quote
Old 11-09-2011, 12:34 AM   #2
43 years in construction
Arkitexas's Avatar
NiCad batteries don't store well and tend to leak. Inspect them at regular intervals for a crusty appearance around the ends. Occasional full discharge and recharge will extend the life better than no use at all. NiCads should always be fully discharged before recharging. If not, they tend to "remember" the shallow discharge level and not permit future discharge below that point. If the NiCad batteries go bad, replacement cells are available but you may need to solder them into the original pack housing and terminals. My last Makita drill had NiCads which died. I replaced them with a LiPo battery pack which holds a charge for months and lasts longer than the NiCads. You can buy a charger made for radio controlled plane LiPo batteries if it is for the same voltage and amp rating.
Rick
Arkitexas is offline   Reply With Quote
Old 11-09-2011, 12:56 AM   #3
Thadius856's Avatar
Rewards Points: 504
You can apply a $0.99 packet of battery terminal protector from an auto parts store if you're really concerned about the terminals.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
storage entrance Mark55 Carpentry 2 03-24-2011 11:19 PM
Crawl Space into Mini Storage Room Mikef5000 Building & Construction 2 03-01-2011 06:01 PM
Adding storage to window seat apruden Carpentry 2 11-06-2009 04:54 PM
attic storage storageseeker Building & Construction 2 01-29-2009 08:02 AM
Attic storage - construction type? rt4me Building & Construction 4 01-01-2009 04:33 PM
