New HF Cememt Mixer Problem - Tools - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 10:50 AM   #1
Rewards Points: 129
New HF cememt mixer problem
Hello all - I posted a problem with the mixer a few weeks ago. I got it going with a new start capacitor. Yesterday the mixer started normally and mixed two loads of concrete. After that it quit self starting - I had to manually turn the drum to get it started. It seemed like the capacitor stopped doing it's job. Another weird thing - the motor turns the drum clockwise sometimes and counter clockwise other times. I believe the drum is suppose to turn clockwise. I'm wondering if the alternating rotation has something to do with the capacitor? Perhaps I wired it incorrectly? Ideas? Thanks
Jack E is offline   Reply With Quote
Old 10-21-2012, 01:44 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jack is this the Mixer in Question?
How much was a Load?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-21-2012, 07:33 PM   #3
Rewards Points: 129
Yes, that is the mixer. The load was two 60 pound bags of concrete and the necessary water to mix. It seemed to handle the load OK.
Old 10-21-2012, 08:00 PM   #4
kwikfishron's Avatar
Rewards Points: 82
There's a wiring diagram in the product manual if you think you may have got that wrong. I've used that mixer before and had the same problem (two 60 lb sacks) until i figured out it works just fine with a little TLC.
Start with just one sack and make it soupy then gradually mix in the second sack. You have to realize this is a bottom of the barrel mixer, it's not a pro tool, treat it as such and it works just fine.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
PaliBob (10-22-2012)
Old 10-21-2012, 08:17 PM   #5
Rewards Points: 129
Thanks for the heads-up on the mixing. I think I'll take the motor out and inspect how I wired it. As I recall the power cord had the green, black, white (ground, hot, neutral?) As I recall there were multiple options as to where you could attach the hot and neutral to the switch. Maybe I didn't get it right. I have to admit I don't have the knowledge to completely understanding what the wiring instructions are telling me. Another thing to figure out
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
