Never Used A Nail Gun. Help! - Tools - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 09:50 PM   #1
Rewards Points: 81
Never used a nail gun. Help!
I borrowed a Bostich 6 gallon pancake compressor and 3 guns for a project. No instructions though. I believe it is this kit. http://www.amazon.com/Bostitch-Facto...sim_sbs_misc_2
I am having a tough time getting the nail depth dialed in. What does the knob on the back of the gun do? It doesn't seem like it does anything...? How do I "max out" the nail driving capacity?
I plan on doing toe kicks, shoes, coves and quarter rounds for a kitchen remodel. Should I plan on adjusting the depth between between material?
Total Tool is offline   Reply With Quote
Old 04-02-2012, 10:10 PM   #2
Rewards Points: 14,300
Ok you have three differant guns, which one are you using?
Should be using the trim gun.
There should be a + and a - sign on the knob. + is more depth.
What's the pressure on the tank? There should be two gauges. The one on the left is the tank pressure and the one on the right is the pressure to the hose. If the knobs not working then the pressure may be to low.
Total Tool (04-02-2012)
Old 04-02-2012, 10:31 PM   #3
Rewards Points: 81
I have tried all three guns. I used the finish (16 gauge I think) nailer on a changing table project with good results. Better than testing actually for some reason.
I planned on using the brad nailer (18 gauge I think) for the kitchen. I'm open to suggestion though. I have never used air tools before.
There isnt a + or - indication, just arrows. I imagine it's right = more driving depth and left = less. The wheel on the back of the brad driver will turn forever. The finish nailer feels much tighter. Either way, the little wheel on the front seems to do more for the depth than the on on the back.
Old 04-02-2012, 10:34 PM   #4
The only gun your going to need for the jobs needed is a finish gun. I own two brad nailers and have never once used them.
Old 04-02-2012, 10:55 PM   #5
Rewards Points: 81
The finish nailer currently loaded with 2" nails. Is that too much for the small trim pieces? Should I get some shorter nails? or is 2" a good length?
Thanks for the help. I am trying to feel this out without screwing up my trim pieces.
Old 04-02-2012, 11:12 PM   #6
2" is to long for trim, try 1-1/2" or better yet 1-1/4"
Old 04-02-2012, 11:33 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Fyi, those dials with the arrows on the top of the guns that just spin,They allow you to direct the air that's released when you fire the gun away from you/your face.
sublime2 is offline   Reply With Quote
Old 04-03-2012, 06:31 AM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
the length of the nail your using depends on the thickness of the material you are working with... the thicker the material the longer the nail required
the depth adjust should be up front on the gun around teh trigger or near the nose. as for the thing on the back that sounds like your talking about the exhaust port. definitely try dialing up the air pressure on the compressor as well
woodworkbykirk is offline   Reply With Quote
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 05:31 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 12:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 06:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 08:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
