Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-30-2009, 06:15 PM   #1
need rec's on air stapler for lattice job
I'll soon be making my own lattice out of WRC.
The two slats will be roughly 1/2" thick each.
Just been browsing staplers on Amazon and eBay, and am not sure what kind of diameter I should be using, or what "crown" means.
Seems I could pick up something used in the sub $50 range, which is perfect.
Then I'd be buying stainless steel staples.
Any recommendations on gauge, staple size, etc...?
Thanks.
wombosi is offline   Reply With Quote
Old 05-02-2009, 05:17 PM   #2
Tool Geek
PaliBob's Avatar
Crown is the distance between the legs.
For lattice 1/4" crown galvanized staples are most commonly used.
Tool King has a good buy on a PC reconditioned Narrow Crown Stapler for $40.
http://www.toolking.com/products/420...lebase=NS100AR
This model from PC is limited to 1" max length staples, which should be fine for your application. I would grab this deal if I did not already have the next bigger model.
http://www.westerntool.com/product.htm?pid=422622
You can buy SS Gun Staples but they are hard to find and very expensive. Note on this link that Senco says use Stainless for ACQ, but you should be fine with galvanized on Western Red Cedar.
http://www.dhcsupplies.com/store/p/1...l?feed=froogle
& Stay Safe
.....Bob Lavery
Bamboo: Nailer or Stapler? Shifterson Flooring 5 12-23-2011 09:43 PM
fixing dropped air stapler cwebber Tools 7 12-24-2010 08:41 PM
Home security installer recs in Boston? dragonness Electrical 4 03-02-2009 03:30 PM
BOSTITCH Hardwood Flooring Stapler Ciprillius Flooring 3 11-28-2007 08:16 AM
