-   Tools (http://www.diychatroom.com/f29/)
-   -   Need motor for old joiner/planer (http://www.diychatroom.com/f29/need-motor-old-joiner-planer-64535/)
jaxjayhawk 02-15-2010 03:37 PM
I have an old Craftsman 4 1/8 joiner/planer, 5/8 hp, model: 149.236221 that the motor just burned up. Sears parts states that the part is no longer available. Does anyone know of a generic replacement or is a new unit the only alternative?
Thurman 02-15-2010 04:51 PM
I can't give you the answer as to a direct replacement motor, and that's probably one of the older "real" units. Suggestion: Having "hands-on" working knowledge of having to have older electric motors re-wound---would this be an option for you? In my area we have two really good, locally owned, rewind shops, and a third which is a branch of a larger outfit. If nothing else, take the motor to them with the units serial and model number for an estimate. Good Luck, David
jaxjayhawk 02-15-2010 05:18 PM
Thanks for the suggestion. I'll look around here in Jax,
47_47 02-16-2010 06:28 AM
Most newer electric motors have a standard NEMA frame size.
http://www.engineersedge.com/nema_frames.htm
Measure yours and if the frame size is standard, then find a replacement with the same frame, input voltage, hp, amperage and RPM.
