Need Ideas To Patch A Rusted Wheelbarrow - Tools - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 07:06 PM   #1
Need Ideas to Patch a Rusted Wheelbarrow
Any ideas on how to patch a rust hole in a wheelbarrow? The cheaper and simpler the better. Let the brainstorming begin!
applebuilder is offline   Reply With Quote
Old 07-19-2009, 08:06 PM   #2
motivator
Speedball's Avatar
Small pieces of sheet metal from a hardware and rivets or self tapping screws to hold them in place.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 07-19-2009, 09:51 PM   #3
Solution
Buy a new one!
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 07-19-2009, 10:11 PM   #4
Haha, I said cheaper!
Old 07-19-2009, 10:19 PM   #5
Fix it water tight ? Or?
Sheetmetal & screws/rivets as stated
Or cheap would be bubble gum/duct tape
Old 07-21-2009, 11:00 PM   #6
Flatten a tin can and screw it down. If you need it water resistant, use some caulk or body putty. Then give the whole thing a heavy coating of rust proofing primer.
jimofoz is offline   Reply With Quote
Old 07-23-2009, 12:10 PM   #7
This should fix you up...
JonM is offline   Reply With Quote
Old 07-23-2009, 12:19 PM   #8
the Musigician
DangerMouse's Avatar
clean edges of hole(s) ...duct tape under it, pour on some 2 part JB Weld epoxy steel filler (feather edges to clean areas) and call it a day.
take tape off the next day or leave it there. keep hole level while filler is setting up.
cheap and strong.
DM
Old 07-26-2009, 10:23 PM   #9
Rewards Points: 1,016
fiberglass tape and bondo?
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 05:25 AM
Raspberry patch.... Jshakour Landscaping & Lawn Care 2 08-14-2008 03:17 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Floor patch HomeDepot23 Flooring 2 07-24-2008 06:03 AM
