Need Help W/ Toro Snowblower - Tools - DIY Chatroom Home Improvement Forum
Old 02-14-2008, 10:01 AM   #1
Need help w/ Toro snowblower
I have a Toro 8hp snowblower that recently started to run poorly.
It seems to pulsate between normal and very low RPM's, back and forth....I'd say every 2 seconds. Also, the exhaust is kind of black, and it's been stalling under load. I messed around with the screw under the carb bowl a little, and it seemed to help for awhile, but went back to running poorly.
Any ideas?? Thanks.
Rigby is offline   Reply With Quote
Old 02-14-2008, 03:03 PM   #2
How old is the spark plug?
How old is the gas?
Does this unit sit outside or inside?
redline is offline   Reply With Quote
Old 02-14-2008, 05:23 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,...
It sounds like the Carb is full of Crap,.....
Try Cleaning the bowl out......
Old 02-15-2008, 02:38 PM   #4
Rewards Points: 150
do normal service on it ,, air filter , plug,, etc then reajust the carb correctly (bowl cleaned)
comp is offline   Reply With Quote
Old 02-17-2008, 09:44 AM   #5
Check for a restricted exhaust. Sounds like backpressure, possibly a bad muffler.
End Grain is offline   Reply With Quote
Old 02-17-2008, 09:49 AM   #6
Rewards Points: 150
they can get a build up in them
ariens snowblower traction skidad Tools 2 12-17-2007 05:32 PM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 01:27 PM
Toro 521 electric starter repair hwm General DIY Discussions 4 12-12-2007 10:28 PM
Toro Snowblower problem mbgrdido Tools 3 12-07-2007 11:28 AM
Replacing a Snowblower belt Niagarafalls General DIY Discussions 3 12-04-2007 06:53 PM
