Need Help With Selecting Drill - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 11:31 AM   #16
jschaben
Rewards Points: 502
Probably the best advice I have would be to get GOOD driver bits. Most of the cheapies are to soft or to brittle. Once it does cam out, and phillips drives are designed to cam out, the drive surfaces of the bit become rounded or broken. either condition leads to more cam outs and ruined screws.
Actually, I'm starting to become a fan of using the impact to drive phillips screws and a bigger fan of Robertson and Torx drives. Posidrive is pretty decent also.
Incidentally, I googled that 12 V B&D and the specs indicate 11 clutch settings but you only mentioned 1-10. Could it be that #11 is a direct drive setting for drilling and heavier driving jobs?
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-21-2012, 02:10 PM   #17
I am using the drill today and I went and got a small pilot bit to assist in getting the screws in easier and it is working pretty good. At least a lot easier than not having a pilot hole. I really like having this key-less chuck though so I can switch bits out so fast! I am still just getting used to it now and I hope I can self-teach myself some techniques.
Zefrik is offline   Reply With Quote
Old 07-21-2012, 02:15 PM   #18
Originally Posted by PaliBob View Post
Zef, If you are messing up the heads of screws using a corded DeWalt it
is because a corded Drill is almost always the wrong tool to drive screws.
You can feather down the drill speed with the trigger to almost get the
screw seated but with no built in Torque Adjustment control there is no way to reliably Guess the proper torque.
The screw will be either not fully torqued or over torqued, messing up the screw head
A Drill/Driver is a different tool because it has a Torque Adjustment.
Yeah, that is the drill I got. I am drilling pilot holes now and it is quite a bit easier than before.
Do you think I need to return this again and get a drill/driver?
Are Drivers variable speed?
Can I get one under $100?
Sorry for all the questions.
Old 07-21-2012, 03:49 PM   #19
What's the rpm rating? When I mentioned a dewalt corded I was thinking of the 0-850rpm Dw235. Slow 0-550 or 0-850rpm corded drills offer more control driving than 0-1100 or 0-2500rpm drills. They also have the torque to drive timberlock screws,lag bolts and mix heavy consistency substances.
toolaholic is offline   Reply With Quote
Old 07-21-2012, 04:29 PM   #20
The thing I like about cordless drill/drivers is that they have 2 speeds; high for drilling and low for driving. I rarely use a cutch for driving long deck screws. I do use it for smaller screws. Impact driver best bet for driving screws but they are not the best drills for over 1/4 inch bits.
Old 07-22-2012, 11:46 AM   #21
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Definitely NOT
That DeWalt DWD 110K is a great VSR Drill at 8 Amp & 2500RPM that will drill fast through home shop projects and will last you forever.
Yes
Not with two Li-Ion batteries
Zef, In Post #7 You found that Li-Ion Black & Decker Drill/Driver but
The hidden truth in all these cordless tool ads is that they only include
One battery unless other wised stated (usually very prominently)
The other consideration on picking a Drill/Driver for home use is the
Question of which cordless tools in the future?
If for example, you are thinking of maybe getting a cordless circular
Saw, then buying a Black & Decker Drill/Driver now would work against
you Because there are no Black & Decker cordless Saws. The most
economical set of cordless tools would all be the same brand.
The lowest cost brand that I would recommend would be Ryobi.
Here is a CPO outlet that has a 18V Li-Ion Drill/Driver for $120
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-22-2012, 12:15 PM   #22
jschaben
Rewards Points: 502
I'll second Bob's recommendation of the Ryobi kit as a good, entry level package. I also will recommend CPO as about as good an internet retailer as you will find, this side of Amazon anyway. Another reason for recommending Ryobi is they have a whole array of tools centered on their 18V volt system. I think all the tools on this link will work with either the nicad or di-lion batteries, the only difference in the system being the charger. Not even sure about that because some of the newer chargers will distinguish between the two chemistrys and charge either.
http://www.cporyobi.com/ryobi-18v-on...efault,sc.html
John Schaben
Old 07-22-2012, 01:13 PM   #23
Alright thanks everybody for the help!
I think I will just keep the Dewalt for now as it is doing what I need it to do. It is very similar to the black and decker corded drill my dad has so I am used to the feel of it. I think maybe in the future when I am doing more projects I will think about getting some good cordless stuff.
Right now the tools I have are (I might have the names/specs wrong) ...
Dewalt Corded Drill
Craftsman 2hp circular saw 7.25in blade
Ryobi Mouse sander
Dremel 200
Do you think this is a good start with power tools?
Is there any other tools I might need?
Old 07-22-2012, 01:24 PM   #24
I'm not a fan of 0-2500rpm drills. They drill fast but have no torque. Only good for drill bits approx 1/2 inch or less. And they are hard to control driving screws. A 0-1100rpm drill is a good compromise between the slow 1/2 inch 0-550/850 drills and the super fast 0-2500 drills. The 0-1100rpm can handle smaller hole saws and auger bits plus are decent drivers.The 2 fast drills I own ,a 0-2500 Makita and the Bosch 0-1000/0-3000rpm two speed 1194 hammer drill, I use wire brushes with to clean up rust before painting.
Old 07-22-2012, 01:29 PM   #25
Dewalt Corded Drill
Ryobi Mouse sander
Dremel 200
Maybe a random orbit sander or belt sander as the mouse sander is only good for detail sanding not major sanding projects ie sanding large areas.
Old 07-22-2012, 01:29 PM   #26
Those people having corded tools and those little plugin wattmeters can help answer questions like this in the future for cordless tools
by noting watts and the time to do common tasks like driving screws (what length, what wood?), cutting two-bys (how fast?), drilling masonry, etc.
You want the peak watts and the watthours or wattminutes. Then you can predict cordless performance.
Old 07-22-2012, 01:46 PM   #27
In a little over my head
Rewards Points: 706
Skip the mouse sander. One of the new "oscillating multi-purpose tools" (multimaster clone) will sand as well, plus do several other things. A random orbit sander will pick up where the MM leaves off. A 1/4 sheet palm sander uses much cheaper sandpaper than either the MM or DA, if that matters.
ratherbefishing is offline   Reply With Quote
Old 07-22-2012, 04:53 PM   #28
jschaben
Rewards Points: 502
I would second the multi-tool as the next target. Prices have come down drastically since Fein's patents expired and it is a very useful tool. Cuts anything from drywall to wood, not so good on ferrous materials but on non ferrous metals it does great. One of my favorite jobs with it is reglazing windows. With a scraper blade that old glazing just jumps off. Usta hate that job. Get a variable speed.
John Schaben
Old 07-22-2012, 05:26 PM   #29
Prices have come down even for the fein. I scored a Fein 250 Q for only 149.99 on clearance at Home Depot on Saturday. I even saved 14.99 on top of that with a Home Depot credit card 10% off coupon.
Old 07-23-2012, 06:19 PM   #30
I see what my next tool purchase will be then!
I just used the drill today to cut a hole is some 3/8in glass!
I am also stripping the stain off of a buffet and I am doing some of it by hand and some with a scraper and the rest with the mouse sander. It feels nice to be able to do some stuff now that I have the equipment!
Tags
beginer , drill , power tools , powerful , selection
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 09:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
