Need Help Picking Out The Right Drill - Tools - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 06:22 PM   #1
Need help picking out the right drill
I am drilling through railroad ties and am having trouble with getting enough power to get through the ties. It is a lot of effort. I have a Bosch, a Dewalt and a Makita. I could get the exact sizes but they are all geared toward normal usage. New carbide tip drill bits do not help.
I was thinking more power.... When I was a kid my dad had a massive drill with a 3/4" chuck. It seemed to do the trick and it had lots of kick. Enough to hurt if you were not paying attention.
I have tried hammer drills but this is not concrete and I do not feel it has the same effect.
I am not looking for a brand war just simple facts or suggestions.
Dean
Dean M is offline   Reply With Quote
Old 12-11-2010, 09:08 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Look for a 1/2" drill with a steel body and a D-handle. They are commonly know as "mud mixers" as they are mainly used by drywall contractors to mix drywall compound. They are torque monsters, and if you aren't careful they will spin you around like an amusement park ride. You might be able to rent one. Most of the big name brand compainies offer them
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Dean M (12-13-2010)
Old 12-11-2010, 10:31 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Also only look at plug in drills, for stuff like this. Battery ones are great for small quick projects around the house, but nothing beats a plug-in one as far as power. My Dewalt plug-in drill makes my 12v Mastercraft look like a baby's toy.
Old 12-12-2010, 08:15 AM   #4
kwikfishron's Avatar
Rewards Points: 606
Are you using a auger bit? If not you should be.
kwikfishron is online now   Reply With Quote
Old 12-12-2010, 09:11 AM   #5
KemoSabe
loneframer's Avatar
I've used a Craftsman drill, very similar to this one, with a 3/4" auger bit to drill through 12" CCA treated marine pilings. It would probably spin you around before stopping. Mine has the same RPM rating as this, 450.
loneframer is offline   Reply With Quote
Old 12-12-2010, 10:58 AM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
yup,.... metal body, D-handle..... that'll do it!
Dean M (12-13-2010)
Old 12-13-2010, 05:57 AM   #7
Need help with a drill
I am a little new at the reply. In short. Auger bit (check). D handle (check). Metal casing... not so much. Need to upgrade. Currently using the Bosch Bulldog with limited success. Too low power. Where can I find a metal casing drill? The big three seem a little light on inventory.
Old 12-13-2010, 07:56 AM   #8
Rewards Points: 558
You can also try this bit http://www.bamanufacturing.com/page_47.htm and use the above “D” handle style drill.
epson is offline   Reply With Quote
Old 12-13-2010, 02:29 PM   #9
Handyman
Rewards Points: 512
I have a Makita which I use specifically for mixing mud/ thinset...incredible torque. And, yes, if not careful you can also sprain a wrist!
canadaclub is offline   Reply With Quote
Old 12-28-2010, 09:11 AM   #10
if you buy a plugin drill dont go with a super cheap one they will just brek i would either go with an industrial one or bosch and makita i dont care for dewalt they just burn up
oscar2129 is offline   Reply With Quote
Old 12-28-2010, 09:25 PM   #11
get a hole hawg (right angle for electricials). I have a Milwaukee but I have heard good things about others as well. I have used mine to drill about 1500 RR ties on many different landscaping projects. It drives the bit slower but will not bog down.
bc0604 is offline   Reply With Quote
Tags
drills
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 01:58 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
