Need Help With A Circular Saw - Tools - DIY Chatroom Home Improvement Forum
Old 11-07-2007, 07:19 PM   #1
Need help with a circular saw
Hello,
I just brought a new 6.5" B&D circular saw, how come the blade is spinning on reverse rotation, instead of spinning counter clock wise, it's spinning clock wise.
707782 is offline   Reply With Quote
Old 11-07-2007, 07:37 PM   #2
Remodeler
MinConst's Avatar
Your holding it backwards
You plugged it in backwards
Seriously if it is running clockwise take it back.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 11-07-2007, 07:55 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What side of the equater are you located in?
J/K....
What MinConst said...
- Build Well -
Old 11-07-2007, 08:32 PM   #4
Is it a right or left-handed saw? Either clockwise or counterclockwise could be correct, depending on the orientation of the blade to the motor. The important thing is that the front of the blade is traveling up. If the front of the blade spins down, you should definitely take it back.
BTW, 6.5" circ saw? Is this a cordless or something? Strange size.
NateHanson is offline   Reply With Quote
Old 11-07-2007, 09:12 PM   #5
not a total Newbie
Also, make sure the blade isn't on backwards... There's usually an arrow that indicates the direction it's supposed to go -- that plus what NateHanson said above should let you know if it's working.
space_coyote is offline   Reply With Quote
Old 11-07-2007, 09:17 PM   #6
I'm using a masonry blade, I want to cut some bricks with it.
Old 11-08-2007, 07:50 AM   #7
RippySkippy's Avatar
ALL hand held circular saws spin so the blade goes up at the front of the saw regardless of which type you have.
RippySkippy is offline   Reply With Quote
Circular saw recommendation? Lonicera Tools 14 10-07-2010 09:30 AM
circular saw rpm-is that the motor or blade rpm? airpwr1@graceba.net Tools 13 06-28-2009 06:28 PM
12 amp circular saw - how powerful is it? handbanana Tools 4 04-20-2007 10:04 AM
closing circular duct steve6 HVAC 7 02-22-2007 08:06 PM
Using circular saw boxer1-2 Tools 9 12-28-2005 08:19 PM
