Need Help, Bit Stuck In Drill - Tools - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 07:22 PM   #1
Rewards Points: 152
Need help, bit stuck in drill
I have the white makita power drill. I have a drill bit stuck in the drill right now. I can't loosen the chuck. I tried to loosen the chuck with an adjustable wrench, it didnt work.
I just wanted to know if theirs a trick to loosen the chuck.
humberguy is offline   Reply With Quote
Old 03-01-2012, 07:51 PM   #2
kwikfishron's Avatar
Rewards Points: 818
Spray the chuck down with some penetrating oil and let it sit overnight then try again.
kwikfishron is offline   Reply With Quote
Old 03-01-2012, 07:58 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
is this a drill/driver or a impact driver?
if its a impact driver tap the bit with a hammer a few times lightly it can loosen it up.. if its a driver bit something thats worked for me is to take a long screw and drive it into some 2x4's then back it out,, try the bit.. if its still stuck try it again in a new hole.. if that doesnt work sometimes clamping onto the bit with vise grips .. hold the vise grips and pull the drill trigger
woodworkbykirk is offline   Reply With Quote
Old 03-01-2012, 09:20 PM   #4
Rewards Points: 512
get your wife to turn it to get it out! haha just kidding!
princelake is offline   Reply With Quote
Old 03-02-2012, 06:32 PM   #5
Rewards Points: 152
I have a drill/driver drill with a cone bit stuck inside it. Im gonna try the penetrating oil and try tapping on the bit tomorrow. Ill see what happens.
Old 03-02-2012, 08:53 PM   #6
a cone bit? you mean a countersink bit or a reaming bit for making holes larger in metal..
anyhow.. if you cant get it out take it to a power tool service center, they can get it out
Old 03-03-2012, 09:25 AM   #7
It may help if you can whack the three jaws that hold the bit into the chuck, gently.
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
drill bit getting stuck and twisting hand amakarevic Safety 12 10-20-2010 11:21 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Help!! Drill bit stuck in door starente General DIY Discussions 4 01-21-2007 01:53 PM
