Need Good Driver Bit Set. Recommendations? - Tools - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 01:18 AM   #1
Rewards Points: 150
Need good driver bit set. Recommendations?
I have a Craftsman 180+ piece tool set that came with about 10 different bit drivers. The screwdriver bits have both become unusable because the metal was to soft. When driving in a screw it would start to spin and just wear the bit out.
What is the best brand of bit drivers that won't break down on me?
Also, I'm assuming these Craftsman bits don't have the lifetime warranty on them....is that correct?
ConstantChange is offline   Reply With Quote
Old 05-24-2009, 03:58 AM   #2
Oldguy
Rehabber's Avatar
For phillips I have had the best results with the bosch 'gold tip" bits. Lowes has them
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-25-2009, 03:40 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
This 148 Piece set has the following guarantee:
All tools in this set meet stringent new ANSI and ASME specifications and come with a full satisfaction guarantee.
I don't know if your's is the same set, if not Google your set to see if it has a similar guarantee.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-25-2009, 07:02 PM   #4
Tool Geek
PaliBob's Avatar
Lowes is a a good source. Their Website is better than HD.
Pics are of the DW2190 Storage Case that I use for hex bits. I got mine at HD but they are also at Lowes.
Recently I picked up this 100 piece set of hex bits.
Besides having security bits that set has Torx bits and a whole set of US and Metric sized hex shafts. No more looking between a set of US then Metric Allen wrenches to find the right size to put up that Bathroom towel rack. I keep a Magnetic Hex Screwdriver handy to load with the HF bits when installing Bath accessories. It beats trying to maneuver a tiny Allen wrench to tighten those set screws.
Need good driver bit set.  Recommendations?-dewalt-dw2190case1.jpg   Need good driver bit set.  Recommendations?-dewalt-dw2190case2.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-26-2009, 11:16 PM   #5
Rewards Points: 150
I am normally all for Craftsman in regards to pretty much everything. But their driver bits suck!! It is possible to completely wear out a brand new bit on one screw if you let it start to slip at all!
I picked up a pack of about 30 dewalt #2 phillips bits at Home Depot awhile ago. I started using two only because I would have them on two different drills at the same time....those two bits made it through my entire kitchen renovation...and they still are perfectly fine.
To summarize, definitely get dewalt on this one.
dc4nomore is offline   Reply With Quote
Old 05-26-2009, 11:23 PM   #6
Shouldn't you look for some that have carbide tips? Seems to me that that might be a solution to the problem.
jordy3738 is offline   Reply With Quote
Old 05-26-2009, 11:30 PM   #7
Rewards Points: 150
Driver bits with carbide tips? I haven't heard of those...do you mean DRILL bits?
Old 05-27-2009, 12:46 AM   #8
The photo shows screw drivers, like square drive bits or #2 phillips head bits.
I have purchased carbide tip #2 square drive bits for many years for installing cabinets.
Actually, they are called hardened steel tips not carbide my bad.
Here's a link http://www.rockler.com/product.cfm?p...9&cookietest=1
Old 06-07-2009, 02:38 PM   #9
Builder
Try the trend snappy set, perfect for grip, they have the hex end. they also have all the neccessary bits for alot of chippie work!
Generally look for the titanium coated drill bits. the live forever, ive got an impact driver which usually tears bits apart, the titanium bits tent to live forever!
Bramwell is offline   Reply With Quote
Old 06-07-2009, 03:59 PM   #10
Rewards Points: 20
I have used irwin, grabber, and dewalt bits. Just don't buy the cheap sets. If you spend a little more money on the good bits they will last longer and give you alot less headaches.
ponch37300 is offline   Reply With Quote
Old 06-16-2009, 09:47 PM   #11
I use an impact driver bit set for my impact driver because they are forged for impact driver use. These bits should provide longer service for your application. All driver bits will eventually wear out with normal use or heavy abuse (speed/technique). Local borgs carry Dewalt/Milwaukee impact driver bit sets.
aggreX is offline   Reply With Quote
Old 06-17-2009, 02:31 AM   #12
Tool Geek
PaliBob's Avatar
McFEELY'S has longer tough 'Ball detent' ACR bits in 2", 3 ”, and 6" Phillips bits. I much prefer these longer ACR bits rather than any of the 1" bits. For new work I generally try to use square drive screws.
http://www.mcfeelys.com/search/phillips+driver+bits
Disclaimer
& Stay Safe
.....Bob Lavery
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
Good home construction software odigity Building & Construction 5 08-18-2008 11:53 AM
Good 1/2" corded drill? fw2007 Electrical 12 08-05-2008 06:21 PM
What would be good quality paint kenny357 Painting 13 06-07-2007 01:36 AM
