Need To Fix Carpet Shampooer - Tools - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 11:34 PM   #1
need to fix carpet shampooer
I have a Hoover deep vac carpet shampooer and after using it a whole 3 times it will no longer suck up the water I spray on the rug. The motor comes on, the brushes turn, everything works except the suction. Hubby can fix anything and has thought he did, but it still won't suck. Any tips would be appreciated am tired of hearing him talking to himself and staring at the shampooer.
ladywildcat3 is offline   Reply With Quote
Old 05-18-2009, 06:12 AM   #2
Check your intake hoses for blockage and check your gaskets and lid on the waste water tank.
It works like any other wet vacuum, if you have a leak you will lose suction. If you hear the suction motor running at high rpm you have a hose or intake blockage.
Hoover makes a decent unit, I used to repair these and Hoover was at that time least problematic but periodically the entier suction motor would need replacing.
Chemist1961 is offline   Reply With Quote
Old 05-18-2009, 03:49 PM   #3
Hoover deepvac
Hubby has checked that all. The hose isn't blocked, the gaskets are fine, and the motor runs exactly the same way it did before it stopped inhaling the water. He is a small engine mechanic and repairs home appliances quite often, but this has got his really puzzled. I'd hate to pay to buy a new motor after just 3 uses,
As I said, it worked fine 3 times and the 4th it just sprayed the cleaner but no vacuum. Called Hoover and found the rudest person I've ever run into. He acted like I was trying to hold the company up for ransom or something. It was still under warranty at that time but got absolutely no where. Tried to get a manual or anything but got nothing but rude replies.
Old 05-18-2009, 07:15 PM   #4
Does the unit have an upholstery nozzle , if so could it be stuck in the suction setting for upholstery cleaning instead of carpet????
Old 05-18-2009, 09:25 PM   #5
Unhappy
no suction
No, it is just an upright unit with no attachments, wish it did as that's what I wanted when I went shopping but couldn't find one I could afford and since we've had Hoovers in the past thought this one would last a long time too.
It's a Model F-5807 DeepVac if that helps any.
Old 12-04-2012, 06:40 PM   #6
Bissell Pro Heat 2 Carpet shampooer
I have 2 Bissell Pro Heat double brushes, neither one will spray out water or shampoo.mI have tried to run hot water thru them, cant get anything to work. $250.00 per shampooer and neither work!!! Not very old either!
misscorvette84 is offline   Reply With Quote
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
