Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-09-2012, 10:13 AM   #1
Need an air compressor drain plug installed
I have an old air compressor with a tank that does not have a drain plug underneith.
It was a replacement tank from 20 years ago.
How can I drill, tap and install one so it doesn't leak?
Or is it time to just junk it out all together?
stewartlong is offline   Reply With Quote
Old 12-09-2012, 10:28 AM   #2
you would have to have a bung welded on.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-09-2012, 10:29 AM   #3
Time to junk it.
It's not legal to drill or weld on a pressure vessel unless you go have it static tested some place.
Old 12-09-2012, 11:55 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
junk it or take it to a local authrorized air tool repair shop
woodworkbykirk is offline   Reply With Quote
Old 12-10-2012, 09:13 AM   #5
Compressors aren't very expensive any more, and there are lots to choose from. I wouldn't put a dime into one that's more than 20 years old.
250V 30amp 3 post plug on a bandsaw, change the plug to a 4 post plug question benjeremiah Electrical 3 10-04-2012 12:43 PM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
