Name That Tool! - Tools - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 11:26 AM   #1
OregonThe Shower me state
Turbogus's Avatar
Name that tool!
Hi gang,
I'm doing some rewiring on my Jeep and am planning to replicate that with efficient factory crimps. The trouble is, in this consumer desert I live and work in, no one has even seen ratcheting crimpng pliers, much less have them in stock. I'm after this particular die for crimping wires to terminals;
Does anyone know if this particular type of jaws have a name or nomenclature? I've consulted with the EBay seller and he has no information.
Here's another pic of the pliers with this die;
Thanks and a lift of the lynch lid for any help in obtaining these !
Turbogus is offline   Reply With Quote
Old 02-19-2013, 11:47 AM   #2
Rewards Points: 34
See if this helps.
LX-03B Non-Insulated ReceptaclesTab 4.8mm ,6.3mm ,7.8 mm Width Terminals Crimping Tool Plier Crimper 0.5-6mm2 AWG 20-10
http://www.aliexpress.com/store/prod...675684908.html
djlandkpl is online now   Reply With Quote
Old 02-19-2013, 02:46 PM   #3
Turbogus's Avatar
Wow ! Thanks djlandkpl, I noted that part no. on the handle, but Yahoo didn't return anything. I reckon I've got to expand my use of other search engines.
Moreover than the crimpers themsevles I'm hoping to find the jaws themsevles of this design. It'd be great if there were a North American maker of them !
Thanks again,
Gus
Old 02-19-2013, 03:15 PM   #4
Rewards Points: 34
I found it on ebay. The seller is also in China but the purchase may be easier for you via ebay.
http://www.ebay.com/itm/Non-insulate...item257a7b6454
Last edited by djlandkpl; 02-19-2013 at 03:17 PM. Reason: adjusted seller statement
Old 02-19-2013, 03:33 PM   #5
Turbogus's Avatar
Well, dip me in buttermilk. I reckon I got used to my local area being such a consumer desert that I considered EBay to be the same. It's actually an EBayer (different name) that I getting that blue handled one from. Glad to see there's onthers out there.
Thanks again djlandkpl
Old 02-21-2013, 11:44 AM   #6
Rewards Points: 77
Djlandkpl is correct. Its for non-insulated crimps, also for crimping Weatherpak, Delphi, and Metripak connectors, commonly found in all of the newer GM and Ford vehicles (not sure on Mopar). They are the black, grey and blue plastic connectors with rubber inserts.
Check out Waytek Wire. They have all the tools and wiring components you'll need for your job. www.waytekwire.com I believe Waytek sells crimpers that have jaws that can be changed out for different types of crimps.
Just an word of advice, solder all of your crimp connections. During my days as a racing crew chief I cannot tell you how many times I had wires come loose from crimp connections and end up costing me a round or an event win. It will take some extra time but you'll be happy you did it.
gjones is offline   Reply With Quote
Old 02-21-2013, 02:48 PM   #7
Turbogus's Avatar
From what I see on this pair of plier at the jaws is an allen nut so the die is apparently replacable. I've given up on solderless connectors though, ever since I got a soldering gun and butane mini torch that'll quickly and efficently heat the wires more than the old iron I once used. Now I'm hoping to find locally, heat shrink tubing with adhesive inside.
Old 02-21-2013, 02:57 PM   #8
Rewards Points: 77
Waytek has the heat shrink as does McMaster Carr.
The Following User Says Thank You to gjones For This Useful Post:
Turbogus (02-22-2013)
Old 02-22-2013, 09:20 AM   #9
Rewards Points: 131
A local electrical supply house ( no matter how desolate the location, there's usually at least one around ) might have what you're looking for. You'll pay top dollar, but if you're in "gotta have it now" mode.
Ideal makes a whole slew of them, take a look for what you need/want then shop away...
http://www.idealindustries.com/prodS...pmaster&page=0
Chokingdogs is offline   Reply With Quote
Old 02-22-2013, 11:02 AM   #10
Turbogus's Avatar
Great idea! Thanks Choking. I don't mind support local business and it's not like I'll be using years of this stuff.
Old 02-22-2013, 11:41 AM   #11
Rewards Points: 13,712
This is what I've using for that type connector to the past 10 years and never had one come loose.
http://www.service.kleintools.com/To...N/Product/1005
Any box store has them.
Old 02-22-2013, 03:51 PM   #12
Turbogus's Avatar
I believe you! I just stripped the insulation collar off of a solderless terminal and it crimped that sucker HARD!
Old 02-22-2013, 03:59 PM   #13
I shoot dielectric grease in the filling before crimping to reduce corrosion.
Old 02-23-2013, 08:26 AM   #14
Turbogus's Avatar
I too use dielectric grease, but normally just on exposed connections like battery terminals an such. When I was disassembling a Ford fuse/relay
panel to adapt for use in my Jeep, the sticky adhesive sealed very well!
convert cordless tool to corded? jason41987 Tools 14 12-03-2012 09:49 PM
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 07:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
