Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-22-2010, 11:09 AM   #1
Nailers - pneumatic vs. electric (battery)
I was watching Holmes on Homes the other day and noticed they were using an electric (battery-powered) finish nailer instead of an air powered tool. Are there any specific advantages or disadvantages to one tool over the other aside from the obvious not having to lug around a compressor and deal with the air hose?
cellophane is offline   Reply With Quote
Old 04-22-2010, 01:20 PM   #2
It was a dark and stormy
Yoyizit's Avatar
See if you can find out the power delivered to each tool; with elec. tools it's easy. With the other, it depends on flow rate and PSI.
And, tool weight may be a consideration.
http://www.woodweb.com/knowledge_bas...d_Nailers.html
http://www.galttech.com/research/hou...t-nail-gun.php
Old 04-22-2010, 03:57 PM   #3
gmhammes's Avatar
I have found that my paslode finish nailer works great if you use it frequently however for a job here and a job there i can't always rely on it. For the price, i like the my senco nailer with a portable air compressor just a little bit more than my paslode. IMHO
gmhammes is offline   Reply With Quote
Old 04-22-2010, 05:34 PM   #4
battery powered are really expensive! can cost 3 times more than pneumatic. For a home DIYer, it is not worth it IMHO.
I was looking at cordless nailer for a while because I don't have a compressor and don't want to have to lug it around. But even used on craigslist/ebay, cordless is really expensive. I ended getting a set of 4 nailers on sale at lowes for $130. It's a pretty generic brand, but reviews show its pretty good for an occasional-use DIYer.
acerunner is offline   Reply With Quote
Old 04-22-2010, 06:21 PM   #5
yup senco here
The older I get the better I was
Old 04-23-2010, 10:46 AM   #6
gmhammes's Avatar
I saw that set at lowes the other day and although i have not heard of the brand, maybe some reviews would be good for the DIYer's on here that don't really want to go all out with paslode or senco.
Old 04-23-2010, 02:55 PM   #7
no reviews from me yet because I haven't started using it. still looking for a compressor to go with it. But here's what I've found online.
http://forum.doityourself.com/carpen...ails-home.html
http://www.avsforum.com/avs-vb/showthread.php?t=1104405
Also lowe's webpage has it's own user reviews.
Old 04-23-2010, 03:20 PM   #8
gmhammes's Avatar
Lowes has the hitachi portable compressors on sale right now for 179 i beleive.
Old 05-28-2010, 06:16 PM   #9
finally got around to trying it out. I shot a bunch of nails into some scrap wood, so I wouldn't say its a real world test. That said, everything works as described, except for the framing nailer. It does not sink the nail all the way.
I'd say the bigger issue is probably with the compressor. It is 115psi max. I am using a filter so there's a 5psi drop. It drains to 70psi before kicking up again. In the best case, the framing gun will see 110psi, and worse case down to 65psi. Off the top of my head, it is rated for 70 to 120psi. Clearly you have to stay at the top end of that range to work properly. For now, I'm gonna give the framing nailer a fail because it does not operate at the spec'ed psi range. If I get a larger psi compressor, I'll test again.
Old 06-07-2010, 04:59 PM   #10
stupid suggestion, but did you adjust the driving depth of the framing nailer? I'm sure you did
Mr. Michael is offline   Reply With Quote
Old 06-08-2010, 04:42 PM   #11
yep, i did.
the depth of the driven nail varies w/ psi very noticably. At the lower end of the psi range, the nail was only driven in about 1/2".
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 02:11 PM
