Nailer For Hardi - Tools - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 05:06 PM   #1
Rewards Points: 108
Nailer for hardi
Which one have you used or do you recommend? or none at all?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 11-29-2013, 05:10 PM   #2
Framing Contractor
Rewards Points: 126
We use a framing nailer with a 2" round head galvanized nail. Turn the pressure down and flush up the nail head with a hammer as needed.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
digitalplumber (11-29-2013)
Old 11-29-2013, 05:39 PM   #3
Rewards Points: 14,294
I owned and tried to use a framing nailer, roofing nailer, total failure!
I bought this gun and use it for all my siding jobs and even fencing.
http://www.bostitch.com/default.asp?...+Siding+Nailer
A siding nailer uses a smaller gauge nail with a ring shank the whole length unlike a framing nailer.
Old 11-29-2013, 07:22 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
use a siding nailer as mentioned by joe.. the nail has to be flush with the face.. only siding nailers have nails with a thin enough head to do this
the harti nails for framing guns have a much thicker head.. if you set the head flush with the siding it will crack the siding
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 11-29-2013, 07:49 PM   #5
Framing Contractor
Rewards Points: 126
While the siding gun is nice, the framing gun can also work if used correctly. We have used it on several Hardi jobs with no issues.
Old 11-29-2013, 08:37 PM   #6
Registered User
Rewards Points: 526
From the Hardie site;
BLIND NAILING
Nails - Wood Framing
• Siding nail (0.09" shank x 0.221" HD x 2" long)
• 11ga. roofing nail (0.121" shank x 0.371" HD x 1.25" long)
FACE NAILING
• 6d (0.113" shank x 0.267" HD x 2" long)
• Siding nail (0.09” shank x 0.221” HD x 2” long)
Don't shoot the messenger, lol. From; http://www.jameshardie.com/pdf/insta...eplank-hz5.pdf Hz10 is the same, both cover the U.S.
Gary
Old 11-29-2013, 09:17 PM   #7
Framing Contractor
Rewards Points: 126
Of course the OP has not stated which type of Hardie siding, lap, shake, panel, or nailing method.
Old 11-29-2013, 09:40 PM   #8
Rewards Points: 108
8 inch lap board, blind nailing
Old 11-29-2013, 09:46 PM   #9
Rewards Points: 108
Gary, was this for me? I have that document, thanks. Wanting to see what others are successfully using to insert the nails with.
BLIND NAILING
FACE NAILING
Siding nail (0.09 shank x 0.221 HD x 2 long)
Gary
Old 11-29-2013, 10:57 PM   #10
Registered User
Rewards Points: 526
For anyone! I use a siding gun, Joe linked it. Carrying a framing gun when doing siding is heavy on the arm and nail belt as it hangs there when not in use.... bad enough to use when framing (37 years)- like apples to oranges in weight/ease of use/time wasted loading/magazine capacity/nail placement/built in exposure gauge/closeness to board end without blow-out corners- just no comparison, (been-there-done-that) IMO. Depends on if you want the siding product warranty.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 11-30-2013, 08:12 AM   #11
Framing Contractor
Rewards Points: 126
Gary
Been there, done that also! But only for 30 years. In my opinion, a framing gun is a lot more versatile for a homeowner than a siding gun. I also never hang any gun from my tool belt. A framing nailer is an acceptable nailer according to James Hardie.
Old 11-30-2013, 08:16 AM   #12
Rewards Points: 108
I actually have a Bostitch N89C, but have not researched if there are any nails that fit this unit, that would be suitable for nailing hardi?
Old 11-30-2013, 09:50 AM   #13
I use my siding nailer for building slat fences, installing 1 X 4 and 1 X 6 exterior trim, vinyl lumber, building bird houses ECT.
Old 11-30-2013, 02:32 PM   #14
im with joe.. a framing gun is for FRAMING. siding nailers are for siding, putting on fence boards. underlay and other things..
the framing gun is just too aggresive and hte nails have too heavy gauge a head which DO crack the siding far worse and much more often than the siding nailer. ive installed countless panels of the stuff and the siding nailer has been the least worrysome.. ive hand nailed with roofing nails.. used a roofing gun along with even screwing it on a commercial job where we had to fasten to heavy gauge steel studs
as for blind nailing 8" im pretty sure it wont be covered by warrenty if you nail it that way. it has to be face nailed.. theyve had issues with heavy winds blowing it off so now only the 5" exposure harti can be blind nailed
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 01:16 PM
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 01:04 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 03:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
