Nail Gun Wont Shoot. - Tools - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 08:26 PM   #1
nail gun wont shoot.
I have several nail guns that are blowing air out of the top but wont shoot a nail.I have tried everything i can think of and i know its sometying im missing PLEASE HELP?
Julian Fortner is offline   Reply With Quote
Old 05-28-2012, 09:54 PM   #2
Haverhill Trade 1965
If more than one is doing it, check that you are getting correct air pressure. Other than that there are probably some worn, or broken, O rings or other plastic parts inside.
Duckweather is offline   Reply With Quote
Old 05-28-2012, 10:08 PM   #3
Rewards Points: 2,212
I have to take the front plate off my finish nailer clean things and lube and put it back on.
mae-ling is offline   Reply With Quote
Old 05-28-2012, 10:17 PM   #4
jschaben
Rewards Points: 502
I agree with Duckweather, if it is more than one, it is likely an air pressure problem. All my guns work well at 90 psi except the 18 guage brad nailer which needs 100 to shoot reliably (it will work at 90 once I get it going, takes 4 or 5 tries the first time) and my framer wants at least 110 psi.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 05-29-2012, 06:28 AM   #5
Rewards Points: 1,300
Has it ever been lubricated? Each time you use it ist should have a couple of drops of air tool oil dumped in the air fitting. This will keep the seals lubricated and moving properly. May be time for a service rebuild
danpik is offline   Reply With Quote
Old 05-29-2012, 07:59 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
my compressor has 2pressure gauges. Sometimes you might check the tank preasure and see that it is fine, but the regulator will be set at a lower pressure. This will cause the gun to misfire.
Millertyme is offline   Reply With Quote
Old 05-29-2012, 09:21 PM   #7
In a little over my head
Rewards Points: 706
Sounds like low air pressure to me.
If the compressor is OK, maybe a kinked hose?
ratherbefishing is offline   Reply With Quote
Old 05-29-2012, 09:49 PM   #8
Sounds like they've never been oiled and the pistons are all stuck. Try to get some oil in them check pressure and tap the drivers back in. They might reset. Otherwize it's the tool guy to get em fixed.
Tham
Tham is offline   Reply With Quote
The Following 2 Users Say Thank You to Tham For This Useful Post:
JoeCanning (06-03-2012), woodworkbykirk (05-30-2012)
Old 06-18-2012, 08:52 AM   #9
Rewards Points: 850
agree, put oil, push tip on board with trigger pulled, like your firing it, then connect hose. that will pop the piston up. worth a try.
hotrod351 is offline   Reply With Quote
Nail in Top Plate Basement buildit45 Building & Construction 5 04-10-2012 02:56 PM
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 05:31 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 12:21 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 08:11 AM
