Nail Gun Or Stapler Recomendation!! - Tools - DIY Chatroom Home Improvement Forum
Old 01-18-2006, 11:39 AM   #1
Rewards Points: 150
Nail gun or stapler recomendation!!
Was thinking it is time to go real modern and use air staplers, shingle guns, and framing nailers. What brand or models of brands would you reccomend for a diy and medium duty and usage??? Also brands and models to STAY away from???
Have some roofs to do, have 1/2 inch plywood underlayment to (staple) down to 1/2 plywood subfloor AND I always have some framing to accomplish somewhere. Any hints, can two jobs be done with one gun here??? Thanks for ANY help!!!
justdon is offline   Reply With Quote
Old 01-18-2006, 07:28 PM   #2
For roofing guns I like Senco, Hitachi, then Bostich. Then when you are talking about stapling 1/2" plywood are you talking about for a roof. I use framing nailer and ringshank nails for that. Hitachi is the only gun you need to buy for that...
Bob
bob the builder is offline   Reply With Quote
Old 01-25-2006, 08:05 PM   #3
Rewards Points: 150
Thanks Bob
The 1/2"Underlayment over 1/2" subfloor plywood. (takes that to take up space) Sheet vinyl to be put over it. In a kichen-dining- utility area.
Old 01-25-2006, 10:20 PM   #4
Oldguy
Rehabber's Avatar
I do 6 to 8 roofs a year. Been using a Porter Cable for 10 years. I would buy the same again for this light usage.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-15-2006, 12:36 AM   #5
Rapture's Avatar
I sencond the Porter Cable. I bought a 3 gun kit and compressor at a local HD while it was around $150 (or more) off regular price on clearance. I love the tools and would do it again without thinking twice.
Rapture is offline   Reply With Quote
Old 02-17-2006, 10:28 AM   #6
Darylh's Avatar
I like Bostish for heavy work and Porter cable for the lighter stuff and I use defeered stables for plywood underlyment.
Darylh is offline   Reply With Quote
Old 04-16-2006, 04:44 PM   #7
Star Member
All the major brands, DeWalt, Paslode, Bostitch, Sanco, Max, Hitachi, Porter Cable,have good nailers. They have minor differences that give you the chance to make a choice. The new kid on the block with the old name, Rigid, is incorperating a lot of the best featurers of them into their new guns.Zhejiang Rongpeng ,Yuyao Fuhua, Wuxi Weida, Wenzhou Guangli, Dingba and other such names may be the ones to stay away from. They are probably of the same designs as the rest but if you have infeariour alloys,tooling, forging and machining your product goes from China to Harber Fright.
Lefty Lucy is offline   Reply With Quote
Old 05-07-2006, 11:40 AM   #8
I purchased a Poter Cable trim nailer, and was very happy with it until the nail guide broke. This was my fault, and not holding this against them, but when I tried to order a replacement it was not easy. Porter Cable will not sell parts direct to the public, and I had problems with a couple of their authorized retailers I tried to contact. I finally got the part about 6 weeks later. I was not happy with this process and will most likely stay away from them for a while.
A side note: I have never tried to order parts from any of the other manufacturers so please let me know if this is standard process. Maybe it's not just them I have a problem with
landlord is offline   Reply With Quote
Old 05-07-2006, 01:16 PM   #9
Oldguy
Rehabber's Avatar
All parts are readily available for Porter Cable & Dewalt tools from www.dewaltservicenet.com fast shipping too.
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 10 09-07-2016 01:21 PM
buying a nail gun with compressor Dave777 Tools 9 11-28-2011 12:37 AM
What staple gun or nail gun for subfloor justdon Flooring 4 03-31-2011 04:16 PM
Using nail gun on deck fence? darsunt Carpentry 1 05-01-2007 09:11 AM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 09:17 AM
