Nail Gun Question - Tools - DIY Chatroom Home Improvement Forum
Old 10-26-2013, 11:02 AM   #1
jschaben
Rewards Points: 502
Question
Nail gun question
Next spring I am planning on replacing the porch overhead/ceiling with 3/8" beadboard at seen at Home Depot. I have a 16 gauge finish nailer and was wondering if the head on those finish nails would hold the stuff reliably or should I be looking for a different nailer. I also have a full round head framer I know would hold but seems like a bit of overkill not to mention the patchwork.
Any suggestions or am I good to go?
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-26-2013, 11:16 AM   #2
Rewards Points: 13,740
Narrow crown pneumatic staple gun with 1-1/4 staples.
If you do it the right way with T & G strips you can nail right into the tongue just like you would when laying a hardwood floor, or even face nail. The holes are so small there easy to patch.
Old 10-26-2013, 11:42 AM   #3
jschaben
Rewards Points: 502
Good thought Joe, I do have a narrow crown stapler. Thanks, hadn't thought of that.
John Schaben
Old 10-26-2013, 12:07 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
If it is wood I would suggest sealing it front, back, edges, and ends before installing, it could cup on you if not. Stay away from the tempered Masonite type, for out side it will look really bad in short order. JMHO
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
joecaption (10-26-2013)
Old 10-26-2013, 12:18 PM   #5
All the ones I've done in the past 5 years I used beaded PVC. NO PAINTING!!
BigJim (10-26-2013)
Old 10-26-2013, 01:52 PM   #6
jschaben
Rewards Points: 502
I hear you there Jim. Exterior trim I usually prime all 6 faces and at least one coat of topcoat before installing. Then it is just a matter of patching nail holes and spotting.
Joe - I haven't seen any PVC bead board at my local Home Depot (local equals 70 mile round trip) so I guess it isn't available to me.
John Schaben
Old 10-26-2013, 02:31 PM   #7
You would have to go to a real lumber yard or siding supply for it.
http://www.certainteed.com/products/vinyl-siding/soffit
I also use there vinyl cove moulding.
It's made so there's a slot for the soffit to slide into and the bottom part fits tight against the side walls.
It's not a normal vinyl cove that's solid.
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 06:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 08:46 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Gun nail question - framing starts in 3 days RolandOG Carpentry 4 08-05-2008 08:07 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
