Nail Gun - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 05:45 PM   #16
Rewards Points: 42
I have that exact hitachi gun that I got for crown moulding (for $25 from http://bigskytool.com reconditioned with a coupon code posted on slickdeals) and it works like a hot damn.
The only thing is that you have to oil it, but I add 5 drops every 4-5 hours of solid work and no complaints.
Lyzic is offline   Reply With Quote
Old 03-24-2012, 09:56 PM   #17
Missouri Bound's Avatar
Originally Posted by Ravenworks View Post
Or buy a palm nailer.
I added one to my collecting of air nailing tools and glad I did. They really come in handy for those awkward jobs.
I must have missed this post first time around.....palm nailers are fantastic for many things....easy and actually a bit fun to use.
Do you want it your way or the right way?
Old 03-25-2012, 02:45 PM   #18
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,356
palm nailers are great for what their intended for.. however you need a compressor that has a high cfm rating and a larger tank... they drain the tank very quickly.. their also more of a tool geared towards renovators as its a bit of a specialty item for times where odd framing details have near impossble places to get a hammer into or a cordless impact driver and screws.
i use them the odd time and even then its not something id rush out and buy for myself
woodworkbykirk is online now   Reply With Quote
Old 03-25-2012, 03:52 PM   #19
Ravenworks's Avatar
They do use a substantial amount of air but because of the cycle time I would disagree with you,my little pancake compressor keeps up just fine.
For the purpose of the OP this would be fine because he is not doing production work.
Think Home owner -VS- Professional Framer
Ravenworks is offline   Reply With Quote
Old 03-25-2012, 08:15 PM   #20
with todays air nailers next to no production framer uses a palm nailer. they use connector plate nailers which shoot hanger nails in one blast.. plus a seasoned carpenter will recogize a when to install pieces of wood before they get into a situation which makes it too hard to properly fasten blocking.. squash blocks etc
running a palm nailer off a pancake puts a large deal of strain on a small compressor which can cause them to heat up quickly. i run a 6 gallon twin tank hitachi for trim which gets very hot simply blowing off my saws at the end of the day. doing so i have to let it sit for a few minutes afterwords before loading it on the truck. as i mentioned i had the porter cable several years ago and i burnt it out with occasional use for trim only. once i tried running a framing gun off it to frame 3 short walls.. couldnt handle the need for air
Old 03-26-2012, 08:41 AM   #21
I was just about to buy this for some trim for inside the house but the coupon is expired now...
bsmith95610 is offline   Reply With Quote
Tags
nail gun
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 05:31 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 12:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 06:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 08:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
