My Saw Needs Bearings! Questions. - Tools - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 10:39 PM   #1
analogmusicman's Avatar
Rewards Points: 560
my saw needs bearings! questions.
wonder if anyone here can help! I've got a pretty old (maybe 1979-80) Craftsman 10" radial saw. bought it new. the absolute best and most-used tool I have. never one single problem,EVER! it's cut "miles" of wood!
oh,I'd say 9-10 years ago,the bearings started to "go out" (yeah,they sounded bad,but I'm lazy and it still worked well)
now, I'm going to replace those things! so,how hard is the replacement process? should I let Sears do it? cost?
model is 113.19770
tnx,
analogmusicman is offline   Reply With Quote
Old 02-27-2011, 08:50 AM   #2
Household Handyman
Rewards Points: 1,408
You didn't state exactly which bearings, and I'm not exactly familiar with this particular saw, so let's say we're talking about motor bearings. If you're a reasonable DIY person, you should be able to take the motor apart to access the bearings. Problem will be how are the bearings held in? About 10 years old? This was about the time a lot of motor manufacturers using aluminum end bells started changing from using a bolt in bearing retainer to a "roll-over" bearing retainer. This is a method of rolling over some aluminum material to hold the bearing in, and is not a repairable method. Your best bet may be to find an electric motor shop in you area, take the actual motor in for an estimate of repair or replacement.
Old 02-27-2011, 01:25 PM   #3
Rewards Points: 560
this saw is probably 30 years old. what you're saying is that the bearings are most likely held in by bolts? this sounds like something I can handle.
tnx,
Old 03-13-2011, 08:33 PM   #4
Rewards Points: 5,336
tnx,
Bearings are not held in by bolts. Bearings are pressed into position. Unless you have a press, take the motor to a machine shop.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (06-13-2011)
Old 03-14-2011, 06:53 PM   #5
Household Handyman
NO--I indicated that early motors had bolted-in plates to hold bearings in---along with press fits. Late model motors used, and still do use, the "roll-over" flange type retainer. IF you have the motor apart and can see the bearings, you can tell if they have the bolt0-in retainers, or the newer "roll-over" retainers. Best bet would be to take the end bells to a motor shop anyway.
Old 04-03-2011, 09:45 PM   #6
Rewards Points: 560
OK. ordered the motor bearings from Sears. got to do it myself since having it done by Sears is impossible . now all I have to do is find an "arbor press". maybe I can rent one. (somebody said I need one) so how do I use it? what size? 1 ton,1/2 ton,what?
anyway, assuming I get the rotor into the press,how do I adapt the "ram" to push on the bearing? somebody said a socket would work. well,I got lots of sockets! is there written instructions somewhere? got lots of wood to cut so I need to get 'er done in a reasonable amount of time!
tnx,
Old 04-03-2011, 10:45 PM   #7
tnx,
Try looking on You Tube for a video.
You need 2 tools. One to pull the old bearing off and one to put it on.
A local tool repair place would be the place to have it done. I had new bearings(2) put on my 30 year old Craftsman shop vac for $14.00. I took the motor apart and brought them the shaft. I have a 6 ton press and repair most all of my tools and decided this was the best way of getting it done correctly. You can screw it up a dozen ways and there's one way to get it right.
Ron
Old 04-04-2011, 05:09 AM   #8
kwikfishron's Avatar
Rewards Points: 352
I agree with Ron, take it to a shop.
I just had the same thing done, one bearing off and on. Cost me $10 and 10 min.
kwikfishron is online now   Reply With Quote
Old 04-04-2011, 05:27 PM   #9
Rewards Points: 560
well, I DID call a "motor repair" shop awhile back and they wanted $200,but that was before I got the bearings and they would have to take it apart. now,I'll call again when I get it all apart.
tnx,
Old 04-04-2011, 05:42 PM   #10
Rewards Points: 352
I’d just show up at a small shop that has a press and hand it to them with a smile.
It’s a 10 min deal.
The Following User Says Thank You to kwikfishron For This Useful Post:
Ron6519 (04-04-2011)
Old 06-13-2011, 01:09 PM   #11
Rewards Points: 560
an update:
took the rotor to a motor shop and the guy pulled the old bearings off and pressed on the new ones for $7!!!
put the motor back together and it runs like new.
tnx,
The Following User Says Thank You to analogmusicman For This Useful Post:
Old 06-13-2011, 02:53 PM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
Nothing better than breathing new life into a favorite old tool. Ready for another 30 years of service.
Old 06-13-2011, 08:17 PM   #13
Rewards Points: 560
that saw has been the most reliable tool in my "arsenal" for 30 years. if it does HALF as good for the next 30 I'll be a "happy camper"! (provided,of course,that the Lord leaves me down here that long )
tnx,
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
When to sand and other questions... PaintedSurface Painting 4 03-27-2009 09:13 PM
Questions about upgrading electrical stuff in our house Trisha Electrical 8 01-16-2009 06:26 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
