-   Tools (http://www.diychatroom.com/f29/)
-   -   Murray Lawn Tractor (http://www.diychatroom.com/f29/murray-lawn-tractor-45635/)
rambler 05-31-2009 11:10 AM
Murray Lawn Tractor
I have a Murry Lawn Tractor Model# 425600x8A.
When I tried to start it, gasoline poored out through the exhaust. At first I thought it was water.
Thank You
rambler
Yoyizit 05-31-2009 01:54 PM
You have an explosion hazard.
Maintenance 6 06-01-2009 12:25 PM
and perhaps a bad carburator with dirt stuck under the needle valve
Yoyizit 06-01-2009 04:13 PM
Ditto that; I can't see what else could cause this.
rambler 06-02-2009 08:32 AM
Thank You, I'll check it out.
rambler
SDC 06-02-2009 04:16 PM
your oil will be full of gas as well, be sure to change it...
(the same happened to my neighbors)
rambler 06-11-2009 02:57 PM
Reply to all
Thanks for everyone's help. I removed the carb, blew it out with air compresser, and installed a new gasket. There wasn't any gas in the oil. I also took off the valve cover and replaced the gasket.
It now works fine.
rambler:thumbsup:
