Multimeter - Tools - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 01:22 PM   #1
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Multimeter
I have an old/useless/crappy multimeter and I am looking to buy a new one. Flukes are nice, but they cost a bundle. Mostly I would be checking the typical things (continuity, resistance/impedance, voltage, current). Any thoughts?
WirelessG is offline   Reply With Quote
Old 05-17-2011, 01:47 PM   #2
Try searching. Comes up pretty often. Pro's like fluke, most others go with something cheaper.
Multi meter
Mikelite80 is offline   Reply With Quote
Old 05-17-2011, 01:59 PM   #3
WirelessG's Avatar
Rewards Points: 698
Oh, yes....the search function...heard about that one time....
I don't know why I didn't think about that...rookie mistake
thanks for the link
Old 05-18-2011, 09:44 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
If you are not needing temperature readings than high end (tons of functions) Fieldpiece is probably not the way to go but you might want to check out their website anyways to get a feel for their meters.
For regular old resistance and amps and continuity and voltage you can't beat the Fluke T (T-600 and T-1000) series. Relatively inexpensive ($50-ish?, that's a guess) and you can play baseball in the major leagues with that thing and it will still work.
Doc Holliday is offline   Reply With Quote
Old 05-18-2011, 09:50 PM   #5
Make that $125-ish. Great meter, though. Worth every penny.
http://www.fieldpiece.com/clamp-meters/sc46
Many more functions than that Fluke that you can definitely get some real world use from and around $85 on the net. If you walk into an hvac supply house you can bargain a bit. Seen 'em for $75 and also worth every penny.
Old 05-19-2011, 10:49 PM   #6
WirelessG's Avatar
Rewards Points: 698
Bought a Fluke T-5 1000. I'll try it out this weekend. It was about $100 and that's no bad.
Old 05-20-2011, 04:47 PM   #7
You got a good deal on the 1000 they're usually around 150. I have the 600 and the 1000, though I dont ever have much need for the 1000. Overall it's one of my best and favorite meters. I also carry a couple greenlee dm-40's on me, they're relatively cheap, nice small form factor, and handle lower dc voltage as well so i keep one in the car for troubleshooting
D5T_Designs is offline   Reply With Quote
Old 05-26-2011, 09:17 PM   #8
Missouri Bound's Avatar
Buy a Simpson 260 if you want the classic bulletproof meter.
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 09:55 AM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 09:10 AM
How to use a multimeter to tell which one is red? dtc HVAC 1 10-13-2009 06:52 AM
How to use a Digital Pocket Multimeter (to test AA & AAA batteries) ? ehoez Electrical 5 09-01-2008 12:02 PM
Need help identifying multimeter ToddB64 Electrical 9 11-10-2007 01:50 AM
