Multi-task Tool: Repairing Or Not - Tools - DIY Chatroom Home Improvement Forum
Old 11-07-2009, 12:53 AM   #1
multi-task tool: repairing or not
Has anyone ever have a multi task tool(Chicago) burned out on them?
Did anyone ever open the interior and repair or check out what really causes of the tool that suddendly stopped? I open mine and found a broken green wire on one of the brush holder. I'm hoping this is what happen and not the amature itself. I'm afraid to unscrew the brush holder and replace that small wire(green) without poping out the spring,
The green wire seem to broke off above the terminal connector at the entry to brush holder. Do you think I could tackle this problem? I don't have a volt meter or know how to use one anyway to check if it really the broken wire or is it the amature.
multi-task tool: repairing or not-multi-task-tool-006.jpg   multi-task tool: repairing or not-multi-task-tool-003.jpg
eyeglass is offline   Reply With Quote
Old 11-07-2009, 08:31 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
I would try to replace the wire. The thing is already broke what do you have to lose?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 11-08-2009, 03:19 AM   #3
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Fix it
Just strip the wire back a little bit and re-attach. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 11-09-2009, 08:25 PM   #4
wire is so small and it slip between two piece of the brush holder.
Will try it and see, nothing to loose but gain.
Old 11-16-2009, 10:14 PM   #5
Household Handyman
Rewards Points: 1,408
I'm a firm believer that in a case like this you can only learn if you try to repair it and fail, which I bet your won't fail. As stated, it doesn't work now, so go for it as far as repairing it. I have learned a lot from taking apart things which do not work. Sometimes I get them to work, sometimes I'm not so good at it, but I learned something along the way. Good Luck, David
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 07:02 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 01:34 AM
I am looking for a multi tool ultrahunt Tools 4 11-20-2006 10:27 PM
