Mot Spot Welder - Tools - DIY Chatroom Home Improvement Forum
Old 04-14-2016, 06:41 PM   #1
Rewards Points: 63
Mot spot welder
Hey all.
I am in the process or gathering all that I need to make my mini evaporator for sap boiling for next year. I typically use propane but it's getting pricey.
I got a 45 gallon drum I need to weld the top to the drum so it's sealed and will cut out spots in the body to place steam trays pans to boil off the sap.
Since I like doing stuff diy style and love to learn new things I thought I would make one of those mot microwave spot welders.do you think the welds would forge together or is it too thick?
chillz911 is offline   Reply With Quote
Old 04-15-2016, 06:13 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Re: Mot spot welder
Ayuh,.... Never heard of a " mot microwave spot welders",......
'n ya haven't said how thick the drum is, nor what metal it's made of,....
My 1st suggestion is to just go buy a mig welder,.....
Bondo is online now   Reply With Quote
Old 04-16-2016, 11:26 AM   #3
landfillwizard's Avatar
Rewards Points: 512
Re: Mot spot welder
Need more information about what you are going to use for your heat source. If you are cutting holes into the drum why does it need to be sealed? How thick is the drum and what are you using for a cover? I agree with bondo. A small mig welder will do what ever you need. the time spent making one of those welds from a microwave would be better spent using a flux core welder from HF.
landfillwizard is offline   Reply With Quote
What to do about a damp spot on ceiling? hockeyp21 General DIY Discussions 15 06-07-2014 06:02 AM
much hotter spot on floor BlueBSH Building & Construction 8 06-20-2011 10:08 PM
240 outlet to welder Chris D. Electrical 8 04-14-2011 03:04 PM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 01:38 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 01:11 AM
