Moisture Meter Recommandations - Tools - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 08:46 PM   #1
Rewards Points: 262
Moisture meter recommandations
It looks like this might be my next tool investment. How much do you need to spend to get a decent one of these? Any recommendations? Primarily for drywall and wood.
Jim F is offline   Reply With Quote
Old 06-29-2010, 10:30 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Jim F View Post
I......How much do you need to spend to get a decent one.
They start out at $30 to around $400.
I have a competing model but the Lignomat mini-Ligno S/DC gets good press
http://www.lignomat.com/MoistureMete...e.mini.SDC.htm
Issue 5 of the free On-line Magazine This Is Carpentry has an excellent overall view of Moisture meters starting on p76
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Jim F (06-30-2010)
Old 07-05-2010, 03:30 PM   #3
Moisture Meters
I was browsing the web and ran across this thread. I'm the owner of moisturemeters.com (just to be clear, I'm not trying to spam this forum).
I'm assuming you're working with the wood and drywall before they're installed. Afterwards, it gets a bit trickier.
I'd recommend you go with a Wagner, probably an MMC 220. That's you're best bet for accurate readings.
For important background info, whatever brand of meter you get, take a look at this Moisture Meter Video Library that Wagner put up on their website. This side of things needs to be a science, not an art. Most people know pretty well how to guess at proper moisture content in wood, but for quality work, spend some more time learning.
Oh, and take a look at our Moisture Meter Technology page at moisturemeters.com, talking about the technology behind pin and pinless meters.
The mini ligno mentioned above may be sufficient for estimates, but it's too sensitive to non-moisture factors. If you're got the money to spend over 100 dollars, just go all the way and buy that 220.
moisturemeters is offline   Reply With Quote
Old 07-05-2010, 03:36 PM   #4
http://www.nextag.com/moisture-meter...l/compare-html
23
25
50
50
60
62
90
136
Excel says
$62
is the avg price of the entries above
half are between
$25 and
$90
Old 07-06-2010, 12:46 PM   #5
I'd definitely go with the Wagner MMC 220 instead of those listed on that nextag page. The Extech there doesn't deserved to be called a moisture meter any more than two nails, a multimeter, and a correction table does. Perhaps good for a guess, but accurracy is obviously compromised.
Old 07-06-2010, 03:03 PM   #6
If you pay more, do you get increased
accuracy
reliability
battery life
ruggedness
or
stays in calibration longer
or
batteries easier to obtain or less costly
or
less sensitivity to confounding variables
or
other
Old 07-13-2010, 08:18 PM   #7
Rewards Points: 262
Lots of good info here, thanks. I am going to be renovating my other bathroom and kitchen in the near future. For those I am going to want to evaluate the moisture in the preexisting wall materials to determine the need to either dry out or replace before painting. Further down the road, maybe wood flooring materials. More research is probably a good thing but for my occasional use, I probably don't need to go top of the line.
How do I choose a moisture meter? darsunt Tools 3 03-01-2010 12:18 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 07:33 AM
need quick general advice on moisture readings Constant Improvement Flooring 2 12-24-2008 10:11 AM
Moisture in Concrete LBlack Flooring 9 10-31-2008 08:24 PM
