-   Tools (http://www.diychatroom.com/f29/)
-   -   Modifying Makita reciprocating saw to use diff battery. Bad idea? (http://www.diychatroom.com/f29/modifying-makita-reciprocating-saw-use-diff-battery-bad-idea-137791/)
mikegp 03-21-2012 06:30 PM
Just bought a Makita BJR182Z reciprocating saw which is supposed to use a BL1830 battery. I have BL1815 batteries. I noticed the tool just had a little plastic nub stopping the battery from working. Ground it off and now it works. Any danger of damage or injury if I run it like this? Any help is greatly appreciated. Thanks -Mike
princelake 03-21-2012 06:54 PM
i know exactly what your talking about! i know for sure that it wont work with the circular saws either which is annoyyying! i dont understand way they did this other then so ppl dont complain that the little batteries die to quickly. i dont see any issues, i was going to do that with my batteries cause some of my fellow employees had the smaller batteries and working on the same job ppl borrow tools including batteries. i didnt have enough guts to cut the nub.
user1007 03-21-2012 07:00 PM
Bad idea. Pay the piper.
mikegp 03-21-2012 07:25 PM
Can you expand on that? I'm trying to make sure they have a real safety reason for doing it, not just so people have to pay for more batteries. I figure they would make it so the battery wouldn't work at all if was that big of a deal. Or maybe I'm in for trouble.
Hardway 03-21-2012 07:35 PM
Makita BJR182Z 18-Volt LXT Lithium-Ion
Makita BL1815 18-Volt Lithium-Ion Battery
mikegp 03-21-2012 08:19 PM
So you're saying it's ok?
Hardway 03-21-2012 08:23 PM
I am saying that the batteries are the same voltage, so the voltage is not an issue.
Writerís information is for discussion purpose only and should be confirmed by an independent source.
I am not an expert and donít claim to be, these are just my views and opinions.
mikegp 03-21-2012 08:51 PM
One is 1.5Ah and the other is 3.0Ah. I know nothing about electricity, does it matter?
More amps means more power or longer lasting?
woodworkbykirk 03-21-2012 09:04 PM
the thick batteries are just the same as having a bigger gas tank on y our car.
as for reason not to use the compact batteries on a cordless recip or circ saw.. they use up the charge much quicker with a compact battery as opposed to the 3.0 amp ones.. personally i hate using cordless saws. you dont get anywhere near the power you get out of a corded one
Hardway 03-21-2012 09:07 PM
A 3.0 Ampere-Hour will last twice as long as an 1.5 Ampere-Hour which is the amount of electrical charge capacity which gives you a relative measure of how long the battery will last, therefore the higher the Amp- Hours the longer a battery will last before it well need to be charged.
So the amp hour is not an issue.
mikegp 03-22-2012 07:31 AM
Ok, thanks. So beside amps and volts, any other reason not to do this? I know they make some tools that can use either battery and I believe both are charged by the same charger. Thanks again.
Hardway 03-22-2012 07:47 AM
The volts and the amp hours are not an issue that I can see, any other issues I donít know.
woodworkbykirk 03-22-2012 07:26 PM
one thing i can guarentee though.. if you have issues with it and try to take it in for service.. warrenty wont cover it
mikegp 03-22-2012 09:29 PM
Yea, I already altered it. Wouldn't expect them to warranty it. It was only $70, so it's worth it if it's not going to hurt me.
mikegp 03-24-2012 01:16 PM
Just used it to cut down 12 small trees. So far so good. Recharged the battery and it's still good. Going to cut some more now.
