Modify Plastic Carrying Cases - Tools - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 03:29 PM   #1
Modify plastic carrying cases
I always hated trying to get everything back in the case, rolling up the cords, trying to remember what direction this that and the other went. That Bosch hammer drill was probably one of the worst. The case on this Milwaukee is just as strong after I zipped it. It seems I can get more in this way. I like the fact that all many of my bits and screws can be in the case.
paintdrying is offline   Reply With Quote
Old 01-31-2013, 06:46 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Congratulations on modifying that Milwaukee Case. Those blow molded cases make it almost impossible to jam anything else in the case.
How did you do it? The pic of the top half of the clam shell does not show any cut marks that follow the original form of the tool. Just wondering.
Also did you use a Dremel to do the cuts, and what glue did you use?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-31-2013, 08:00 AM   #3
No glue, I just zipped it with my dremel. I was thinking of doing a youtube video but I figured this was an old trick. Took about five minutes to do. I traced it out with a sharpie, leaving key parts of the case intact for structural support, but did go all the way to the edge in one small spot to shake dust out easily.
Old 01-31-2013, 12:51 PM   #4
Tool Geek
PaliBob's Avatar
I don't anything about zipped.
Iv'e cut out partitions on a Panasonic Case but not anything structural. How did you handle all the undulations in the top clam shell?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-05-2013, 09:37 PM   #5
Rewards Points: 29
I have a couple of milwaukee cases that I am going to try and cut this week. I am planning to cut the entire inner layer out. Figure that may make it too 'floppy'. I have some corrugated plastic (like cardboard, but plastic) like political yard signs are commonly made from, but slightly heavier. I plan to cut it to fit the full height and width of the lid and bottom, and glue in to stiffen the carcass up. Will see how it goes.
ranger12 is offline   Reply With Quote
Old 02-06-2013, 05:19 AM   #6
Tool Geek
PaliBob's Avatar
Originally Posted by ranger12 View Post
......I am planning to cut the entire inner layer out........
Now I see what Post #1 meant when he said "I Zipped it" The only case that I modified (Panasonic 14.4V Driver) did not appear to have that inner layer so I just cut off some of the vertical dividers.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-07-2013, 08:36 PM   #7
Rewards Points: 29
I cut the innards out of an older milwaukee case today -- maybe bought that set in 2000 or so. Stiff enough, not too much flex, closes and latches fine. No need for a stiffener.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Bath Tub fix. Plastic Panel? crayola110 Remodeling 1 08-23-2012 05:13 PM
Plumbers Putty on Plastic index1489 Plumbing 0 03-19-2012 12:37 PM
What is the best glue for plastic? sukhenkoi Remodeling 3 03-02-2012 08:29 AM
Chrome paint on plastic Thurman Painting 3 08-24-2010 01:17 PM
