Mitre Saw Smoking - Tools - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 12:15 PM   #1
mitre saw smoking
Hi,
I have a ten inch mitre saw from canadian tire. Its works ok, I replaced the original 24 tooth blade with a 200 tooth fine blade for cutting baseboard and such, I tried using it for 3/4" hardwood flooring, and it starts to burn the wood, and smokes, Is this blade not appropriate for cutting hardwood? The blade seems sharp enough...
bullet is offline   Reply With Quote
Old 06-10-2009, 12:56 PM   #2
Kap
Mowing my life away.
Did you put it on backwards?
Kap is offline   Reply With Quote
Old 06-10-2009, 01:01 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Is it a slider?
If so, it could be that the blade is out of alignment.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 06-10-2009, 01:34 PM   #4
Bullet,
As long as you are cutting across the grain you should be fine. Be sure your material is supported beyond the saw deck if it is more than 3' in length. ..and check the rotation of the blade. Are you cutting hardwood or hardwood laminate?
Chemist1961 is offline   Reply With Quote
Old 06-10-2009, 02:32 PM   #5
47_47's Avatar
Rewards Points: 44
Are you sure that this is not a plywood blade? If it is, it will burn 3/4" hardwood. BTW, I've never seen a 200 tooth 10" blade, who is the mfgr?
47_47 is online now   Reply With Quote
Old 06-10-2009, 02:47 PM   #6
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Sounds like too fine a tooth blade, dull or backwards.
Brik is offline   Reply With Quote
Old 06-10-2009, 11:17 PM   #7
Thanks for the replies,
Its not on backwards , and I wish it was a slider,
Its a fine tooth mastercraft blade, I think it may be too fine
or made for plywood. I'm cutting solid hardwood flooring.
I will change it to a maybe freud 80 tooth?
The damn blades can get expensive.
Old 06-11-2009, 07:44 AM   #8
47_47's Avatar
Rewards Points: 44
Try a Forrest blade, they give excellent results.
Old 06-11-2009, 08:45 AM   #9
Handyguy
Brik's Avatar
It could be its a tablesaw blade. The teeth are different on mitersaw blades. I second the vote for Forrest blades. They will last forever. When they get dull you just send them back to be sharpened. I have two of them, when a blade gets dull I put on the fresh one and the dull one goes in for a sharpen.
For your miter saw.
Forrest 10" blade with 5/8" arbor (most common)
The blade IS expensive. It will make a crappy saw perform well.
Old 06-11-2009, 09:53 PM   #10
47 47 was right, I was using a fine tooth plywood blade,
I will look for the blade you recommended,
thanks.
How to cross cut a mitre on a 1x6 beerdog Carpentry 1 05-28-2009 08:10 PM
Help With Buying A Compound Mitre Saw jte1130 Tools 5 12-10-2008 03:00 PM
smoking cordless battery?? DangerMouse Tools 7 10-28-2008 12:20 AM
Compound Mitre Saw fengler19 Tools 9 08-02-2008 01:18 PM
10 year old mitre saw mt232 Tools 1 08-21-2007 06:38 PM
