Mitre Saw Kick Back - Tools - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 10:52 PM   #1
mitre saw kick back
ok I don't exactly know how I did this but was cutting a 4x4 and got almost to the bottom and the saw kicked back and thought no biggy but when I pulled the trigger it was obvious something was rubbing metal to metal so took the blade off and put it back on and tightened the center bolt real tight plugged er in and pulled the trigger same noise so repeated the steps again but this time noticed that the spindle that holds the blade has slop and after putting the blade back on noticed that I could push and pull the blade and feel the play so what are my options is this fixable or do I need an expert to look at it
Thanx
Robin
rcm572 is offline   Reply With Quote
Old 02-04-2009, 12:18 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
most likely you cant fix it, maybe a spindle bearing that is pressed on
Tom Struble is offline   Reply With Quote
Old 02-04-2009, 07:46 AM   #3
Registered User
Termite's Avatar
You've obviously got a serious runout problem with the shaft or the bearing that will need to be fixed by the tool manufacturer's service center.
back button not working joed Site Help and Suggestions 9 11-12-2008 12:08 AM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-21-2008 11:10 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
central air wont kick in? What have I done HVAC 3 08-14-2006 02:03 PM
