Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-29-2008, 10:47 PM   #1
Mitre Saw Blade
Other than the guard not completely covering the blade, does anyone know of issues with installing a 10" blade on a 12" power mitre saw, as long as the rpm rating and arbor size are appropriate
pgr380 is offline   Reply With Quote
Old 12-29-2008, 11:05 PM   #2
Tom Struble's Avatar
Mitre Saw Blade
you will have to adjust the cutting depth should work ok in a pinch but you should use the proper blade imo
Tom Struble is offline   Reply With Quote
Old 12-30-2008, 12:42 AM   #3
Moderator
Termite's Avatar
Mitre Saw Blade
You can get away with a 10" blade in a 12" saw, but the performance will be different than you get with a 12". The motor RPM's don't change but with a smaller blade the tip speed is lessened due to the smaller diameter.
My suggestion would be to buy the appropriate blade for the saw you have and not use an improperly sized blade.
Old 12-30-2008, 07:51 PM   #4
Mitre Saw Blade
Does the saw come down low enough to complete the cut? It's an inch shorter than the 12 inch blade.
losttool is offline   Reply With Quote
Old 01-20-2009, 11:14 PM   #5
Mitre Saw Blade
...I have put 8 1/4" blades in my 10" table saw before....but never downsized my miter...
TBFghost is offline   Reply With Quote
Old 01-21-2009, 09:48 PM   #6
Mitre Saw Blade
It works Ok - it doesn't fully complete the cut (about 99%), so I wouldn't use it for finish work. Does fine for framing lumber, though.
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
Which saw blade for laminate countertops? Proulx06 Carpentry 5 01-15-2008 09:45 PM
Mitre saw blade for 3/4 in. Oak Hardwood? bajaboy1 Flooring 3 11-29-2007 07:36 AM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
