-   Tools (http://www.diychatroom.com/f29/)
-   -   Mitre Saw Blade (http://www.diychatroom.com/f29/mitre-saw-blade-34672/)
pgr380 12-29-2008 09:47 PM
Mitre Saw Blade
Other than the guard not completely covering the blade, does anyone know of issues with installing a 10" blade on a 12" power mitre saw, as long as the rpm rating and arbor size are appropriate
Tom Struble 12-29-2008 10:05 PM
you will have to adjust the cutting depth should work ok in a pinch but you should use the proper blade imo
Termite 12-29-2008 11:42 PM
You can get away with a 10" blade in a 12" saw, but the performance will be different than you get with a 12". The motor RPM's don't change but with a smaller blade the tip speed is lessened due to the smaller diameter.
My suggestion would be to buy the appropriate blade for the saw you have and not use an improperly sized blade.
losttool 12-30-2008 06:51 PM
Does the saw come down low enough to complete the cut? It's an inch shorter than the 12 inch blade.:eek:
TBFghost 01-20-2009 10:14 PM
...I have put 8 1/4" blades in my 10" table saw before....but never downsized my miter...
pgr380 01-21-2009 08:48 PM
It works Ok - it doesn't fully complete the cut (about 99%), so I wouldn't use it for finish work. Does fine for framing lumber, though.
