Miter Saw Stand - Looking For Sturdy And Portable - Tools - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 11:12 AM   #1
Miter Saw Stand - looking for sturdy and portable
Has anyone found a good STURDY portable miter saw stand? I use a Milwaukee 6955 on projects that I do on the side (mainly molding, lots of corners) on old houses. Jobs tend to be quick in and out 1/2 day or day projects. Looking at easy setup.
Milwaukee makes a stand, but it looks too flimsy/cheap. Heard about a Sawhelper, but haven't seen one in use and would be curious if anyone has used/seen this and if it is sturdy. I don't want to order it online at their site www.sawhelper.com, so if you know if Acme or anywhere carries it, that would be helpful.
thanks
Smitty
schm1eri is offline   Reply With Quote
The Following User Says Thank You to schm1eri For This Useful Post:
Ridge (11-15-2010)
Old 11-12-2010, 01:07 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Smitty, Welcome to the Forum
I have not seen a Sawhelper for sale on other sites.
here is another brand that has a good review & it is cheaper
http://www.amazon.com/Denali-Miter-S...ews/B000MS7B2K
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-12-2010, 01:11 PM   #3
Rewards Points: 48
Bob, not sure, but I sort of read that as spam, or whatever it's called.
Old 11-12-2010, 06:30 PM   #4
Tool Geek
PaliBob's Avatar
Dex, The O.P. asked if anyone other than Sawhelper sold their Stand.
I replied negative because since Sawhelper just got back in the business they are trying to catch up with a large number of orders that were stoked by their favorable reviews in JLC, so they are not ready to reduce any prices as that was part of the reason why they went out of business the first time around.
(Google: Sawhelper, JLC)
I think Sawhelper is the primo saw stand. I was just trying to point out a much cheaper alternative.
The Sawhelper ranges in price from about $450+
http://www.toolsnob.com/archives/200...e_portable.php
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-12-2010, 07:21 PM   #5
DIY staff
Rewards Points: 7,174
That Sawhelper is a fine looking stand----Bob I do think, for quick in and out jobs ,a simpler stand like you pictured will work well.
Old 11-12-2010, 10:03 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Try the sister woodworking site, I'm sure someone there would be able to tell you how to build one or anything you want to know.http://www.woodworkingtalk.com/
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-12-2010, 10:06 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I've been using the Rigid for a while now.
It's portable and very stable
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Tom Struble (11-14-2010)
Old 11-14-2010, 09:13 PM   #8
homeowner learning quick
i have been researching the Rockwell jawhorse and there is a mitre saw accessory for it. You can get the jawhorse and the motre saw accessory for around $200 (maybe a bit more) then you have both the saw stand and the clamp and it is very portable. The jaw horse and all the available accessories is on the Rockwell web site http://rockwelltools.com/jawhorse.htm
whataboutj is offline   Reply With Quote
Old 11-15-2010, 02:38 AM   #9
Household Handyman
Rewards Points: 1,408
I use the DeWalt 723 saw stand in my line of work. Much like you, most of my jobs are a bit over 1/2 day type. This unit folds up nicely and sits on the floor of my work trailer. Easy set-up also. Just my 2 worth, David
Old 11-15-2010, 11:37 PM   #10
firehawkmph's Avatar
Rewards Points: 1,822
Smitty,
I use a hitachi fold up stand. It's aluminum, very light, and works very well. It has a small base that bolts to the bottom of your saw and then fits into the stand using two cam lock levers. Pretty slick. You can carry it with one hand.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-17-2010, 08:34 PM   #11
Rewards Points: 150
I would think that a stand with wheels would be most portable. I really don't see the need to carry a 60lb+ saw and a 50+lb stand in to every job when you could roll the whole set a lot easier.
STL B. is offline   Reply With Quote
Old 11-17-2010, 09:20 PM   #12
ST,
That stand I pictured can be carried with one hand, it is very light. I have a Bosch 10" compound slider that is heavy enough on its own. The rolling stand that bosch sells takes up way too much space in the van and is pretty heavy on its own. A lot of times I encounter steps and such and am usually by myself, so I like having two separate components.
Mike Hawkins
Old 11-18-2010, 12:43 AM   #13
Rewards Points: 150
I wasn't knockin the hitachi stand at all I just hate carrying big saws through houses it's hard on the back and the walls. I have only worked with a few saws on stands and they were all nice and easy to move from room to room but I am usually set up on saw horses and thats a pain in the arse.... many more trips to the van. Speaking of that it sounds like you need a larger one
Old 11-18-2010, 05:01 PM   #14
Hey St,
I have a ford E250 extended van. Can't get much bigger unless I went to a commercial type truck. I can fit about everything I need in mine. I do mostly kitchens and lately have been getting some work remodeling large master baths, involving a lot of tile work. I didn't think you were knocking the hitachi stand, just giving you my experience with it. I am going to a big bi-annual tool sale at a local hardware store. It's more likd a super hardware store, with a lumberyard and john deere dealership together. Neat place. All the tool reps will be there demoing all the new stuff and everything is on sale. Always a fun day.
Mike Hawkins
Old 11-26-2010, 03:51 PM   #15
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by firehawkmph View Post
Smitty,
Mike Hawkins
I have this exact stand and LOVE IT. very sturdy. bought it on clearance at lowes years ago for $59.99 wish i would have picked up a couple extra!! this stand is made by TracRac, they sell it under the Bosch name as well
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Tags
miter saw stand , portable miter saw stand , saw stand
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
10" sliding miter vs 12" standard miter CZSteve Tools 18 08-31-2010 02:40 PM
Portable saw Question Gettingintoit Tools 10 11-03-2008 08:45 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 11:33 PM
Ridgid Miter Saw Utility Vehicle - $99 MoJoe Tools 2 03-05-2006 11:41 AM
