Miter Saw Reapir - Tools - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 09:52 AM   #1
Miter Saw Reapir
I have a Hitachi 10" miter saw that is roughly over 5 years old in which the electronic brake stopped working. So when it's plugged in it starts running and when the trigger is pressed won't do anything.
Is this something that can be fixed at a reasonable amount or am I better off buying another saw. I've seen refurbished Hitachi's on Amazon for $100 while the Harbor Freight 12" slider is on sale for $140 (just not really a fan of HF).
Thoughts?
Surfer4fun is offline   Reply With Quote
Old 02-05-2014, 09:57 AM   #2
Rewards Points: 12,856
Sounds more like a bad switch then the brake.
Should be able to open it up and just test the switch with the wires disconnected with an ohm meter.
Old 02-05-2014, 09:59 AM   #3
How involved is a switch replacement?
Old 02-05-2014, 10:05 AM   #4
Takes me about 15 min.
Take a look at the screws they may be Torx's
Make sure to make a little diagram where the wires go.
Most will need a small flat jewelers screw drive to depress the spring clip holding the wire to the switch.
Old 02-05-2014, 09:53 PM   #5
I did some additional research and it appears the switch is a common issue. I did a quick search and ordered a replacement switch for $11...hopefully that should do the trick.
Old 02-06-2014, 06:25 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
switch is most likely.. if it is infact the electric brake it can also be the brushes
woodworkbykirk is offline   Reply With Quote
My FIRST Miter Saw - Seeking Advice CaptainMarvel Tools 24 11-30-2012 12:41 PM
Hitachi vs Dewalt Miter Saw cstrasz Tools 12 03-11-2012 06:55 PM
miter bar problem ChrisMohrSr Carpentry 2 02-06-2011 09:47 PM
Miter Saw for Framing stubits Building & Construction 9 05-21-2009 06:14 AM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 09:48 AM
