Miter Saw Adjustments - Tools - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 02:43 PM   #1
miter saw adjustments
Hello all,
I'm new here, and I just like to know somethink about a miter saw I just bought.
This morning I bought a Craftsman sliding miter saw (10"). The blade is not square and even if I adjust the fence, the blade is off... Any ideas?
I check all the other adjustments and I can't find anything else.
(See picture)
bouellet is offline   Reply With Quote
Old 02-24-2008, 03:11 PM   #2
Did you check the bevel adjustment? From the angle of the picture, it looks like that is off.
jerryh3 is offline   Reply With Quote
Old 02-24-2008, 03:20 PM   #3
Jack of Some Trades
Wood Butcher's Avatar
are you saying that you found all the adjustments, as listed in the manual and still cant get it square, or that you can't find any other adjustments?
Usually the bladeto table angle is adjusted with a bolt or set screw that basically works as a stop to zero out the bevel
if you still can't get it, return it and try another. like everything else, they are making some of these so cheap that they are impossible to square. I've always been a Makita fan. Most of the ones i own where square right out of the box, or at least easy to adjust
Wood Butcher is offline   Reply With Quote
Old 02-24-2008, 03:26 PM   #4
The bevel is pretty good, I know that from the picture it looks off, but it isn't.
This is the route of the blade | and this is the angle of the blade \ View from the top.
Pretty hard to understand, but I think it's the perfect statement to explain.
Old 02-24-2008, 03:34 PM   #5
If the saw doesn't have positive locking stops, you may be able to adjust the zero pointer.
Old 02-24-2008, 03:58 PM   #6
Originally Posted by Wood Butcher View Post
...if you still can't get it, return it and try another. like everything else, they are making some of these so cheap that they are impossible to square. I've always been a Makita fan. Most of the ones i own where square right out of the box, or at least easy to adjust...
I agree... Called the store and they told me to return it, that it wasn't normal...
Thanks!
Old 02-24-2008, 04:10 PM   #7
Jack of Some Trades
at least you took the time to check it for square. I am always shocked at the amount of people that don't bother, . I guess a square still costs more than a tube of caulk!!
Old 02-24-2008, 10:15 PM   #8
Good one!
Old 02-26-2008, 05:10 PM   #9
Handyman/ Snow Removal
Bouellet,
I also have the craftsman slider. It seemed to work fine, second time I went to use it, the carrying handle broke right off. Also, mine came with the stand, I've currently on my 4, first time it didn't have the actual stand part, just the legs and stuff, second, there weren't any springs in the legs, third the bolts weren't right. I thought the third time was a charm, I guess it's the fourth. Any luck with craftsmen cordless, I've used the 18v drill and one of the battery's wouldn't charge, just wondering if you have one you could comment on? Thank you.
McGaw is offline   Reply With Quote
Old 02-26-2008, 06:31 PM   #10
Originally Posted by McGaw View Post
Bouellet,
For the cordless drill, I have two. One is a 15.6v and the other one is 12v multi usage (sander, drill and saw). They both work find and I have them since 5 to 7 years now. One of the two batteries of the 15.6 is dead, but that's pretty normal, sine I have used it a lot!
For the miter saw, my second one was ok at first, but now, I find that the guide is not true, so....
Maybe, I'll go to have a complete refund... And I'll wait to have the extra bucks and buy myself the new Ridgid 12" miter saw.
I hope to solve the itsy bitsy problem, but I'm a little bit discouraged!
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 08:48 AM
Miter saw stand jonesiera Tools 9 09-03-2006 06:24 PM
Bosch miter saw question.... chrisexv6 Tools 1 08-27-2006 01:21 PM
Question on miter saws Doug Crf Tools 2 06-22-2006 06:42 PM
