Missing Chuck Key - Tools - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 06:15 PM   #1
Rewards Points: 2,072
missing chuck key
Rats. Knew putting this board up wouldn't be easy.
Ready to drill a small hole to make putting the screw in easier.
But the chuck key that's been attached to the cord for 10 yrs is missing.
Lowes has the keys, but was hoping to finish tonight. I don't suppose there's a substitute for that key.
Startingover is offline   Reply With Quote
Old 11-10-2013, 06:21 PM   #2
Rewards Points: 12
You might be able to twist the chuck closed tight enough by hand.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Startingover (11-10-2013)
Old 11-10-2013, 06:22 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,.... Stick a phillips screwdriver type thingy into the Hole in the chuck the "Key" goes into,....
With a straight-blade screwdriver, Lever(against the other screwdriver) the collet cogs around, 'n Tight,......
The Following User Says Thank You to Bondo For This Useful Post:
Old 11-10-2013, 06:38 PM   #4
ok, thanks. And when I do buy a new key how will I know what size, besides taking my drill with me.
Old 11-10-2013, 06:56 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
You answered your own question, take the drill with you. No mistakes that way. Good habit to get into.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
Gymschu (11-11-2013), Startingover (11-10-2013)
Old 11-10-2013, 07:40 PM   #6
bbo
Mike Hawkins
definitely take the drill, not all keys are the same size. note I did not take my drill, that's how I know.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 11-10-2013, 07:41 PM   #7
Davejss's Avatar
Rewards Points: 740
You can buy a keyless chuck and replace the keyed one on your drill. Never worry about lost chuck keys again.
Davejss is offline   Reply With Quote
The Following 2 Users Say Thank You to Davejss For This Useful Post:
Old 11-11-2013, 09:07 AM   #8
thanks for your help.
I'm not mechanical so changing a chuck sounded hard.
Found a universal key at Lowe's. Glad I'm not the only one who's lost one.
Now realize my drill bit is too short to go thru the board, drywall and into the stud.
Will try to put screw in by hand or else look for a long drill bit.
Old 11-11-2013, 09:23 AM   #9
bbo
ooh boy. you should just bite the bullet and get a nice impact drill. I struggled with cheap stuff when I was very young, not having the right tool and/or a good enough quality one. for the stuff you use a lot, just go buy quality. I'm at the point now where my trips to the box or hardware stores are 95% for materials. most of the consumables I get ( drill bits, circular saw blades, etc), I have enough handy and just pick em up when on sale now.
Also I was a bit daunted at changing a drill I had to keyless, but once I did, I was glad. its so much easier to work with a keyless chuck. ( even easier to work with impact bits, imo.)
*good luck with your project !!
Startingover (11-11-2013)
Old 11-11-2013, 10:20 AM   #10
Rewards Points: 12
Rub the screw threads with a bar of ivory soap. It'll drive easier.
MinnesotaSteve is offline   Reply With Quote
The Following User Says Thank You to MinnesotaSteve For This Useful Post:
Old 11-11-2013, 11:30 AM   #11
Rewards Points: 712
Being "not mechanical" and probably not raised during the great depression I suspect you've never made a bit for boring wood from a nail.
Tools and material required:
1) nail of the appropriate size
2) hack saw or side cutters
3) hammer
4) anvil - don't be particular and don't let Mom catch you using her sad iron.
I've always suspected the spade bit was developed from this idea and it's a shame I didn't get the patent.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 11-11-2013, 08:02 PM   #12
I should clarify that I do have a set of drill bits, so I know they come in different lengths. My problem is that the longest is too fat. I need a skinny long one.
Interesting about the depression and rigging one up out of a nail. I've heard lots of stories from my parents about that time. Amazing the ingenuity of people when needed.
EDIT: aha. Now that I organized the garage I found the orig. box the drill came in and at the bottom, was the chuck. Now I have 2 but will probably never use the drill again.
Milwaukee cordless hammer drill - keyless chuck screw stripped eclark Tools 5 09-11-2012 12:46 PM
Replacing Drill Press Chuck blue sky Tools 9 08-17-2012 11:54 AM
How much???? 1910NE General DIY Discussions 19 12-28-2011 12:24 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
B & D chuck Jim F Tools 1 09-09-2010 01:22 PM
