Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-19-2011, 10:18 AM   #1
The Moose is loose.
MooseWoodworks's Avatar
Milwaukee M18 Combo kit w/ Hammer Drill
Anyone here have this kit? I was wondering how useful the 'Hammer' setting on the drill was. I've never had any experience with a cordless model before and didn't know if it was of any use or if I should plan to eventually buy a standard corded model hammer drill in the future.
I bought the M18 combo kit because @ Home Depot you end up getting three M18 Red Lithium XC batteries which would cost you $360.00 plus tax in batteries alone, so I figured the combo was a no brainer at $399.
Here's the actual kit I got if anyone is confused...
http://www.homedepot.com/Tools-Hardw...atalogId=10053
MooseWoodworks is offline   Reply With Quote
Old 12-19-2011, 10:43 AM   #2
I use my hammer drill far more then any of the other tools in that set.
Trying to remove stubborn screws, installing long deck screws, removing and installing outlets, installing lag bolts, removing lug nuts on my trailers with adapters that fit on sockets.
It will even act as a drill with special drill bits with a hex shank.
Old 12-19-2011, 10:53 AM   #3
The Moose is loose.
I am confused. Are you talking about the Impact wrench or the hammer drill? The impact uses hex bits that 'lock' into place and the hammer drill has a regular chuck that you hand tighten. I ain't giving you a hard time I just don't which tool you are referring to.
Old 12-19-2011, 11:07 AM   #4
Hammer drill.
The impact drill is what your going to need to install things like Tap Con screws and any holes in block or brick.
Old 12-19-2011, 03:44 PM   #5
Hammer drill.
You've got that backwards - hammer drill is what you use to drill in concrete, rock, etc. The impact drill is the one that works like an impact wrench you'd use on car tires, rusty bolts, etc.
That being said I have the M12 version of the hammer drill and it works great for installing Tapcons and other smaller holes. Makes the masonry bits cut like butter. I'd imagine the M18 would be even better.
itguy08 is offline   Reply With Quote
The Following User Says Thank You to itguy08 For This Useful Post:
MooseWoodworks (12-20-2011)
Old 12-20-2011, 06:02 AM   #6
The Moose is loose.
I didn't know there was a M12 version. Thanks for the feedback. I've used probably 4-5 different brands of corded hammer drills but never a cordless model. I haven't had a chance to try mine out yet, and so I didn't know exactly what I had. Sounds like it will be plenty powerful enough for the odd jobs I'll do with it.
Old 12-20-2011, 03:47 PM   #7
I tried a Ryobi 18v hammer drill. I returned it an got a 120v rotary hammer. There was such a drastic difference between a hammer drill (that cordless one and others I've had in the past) and a rotary hammer, it just blew my mind.
My experience with hammer drills is that they are only marginally better than low speed regular drills in concrete. The rotary hammer is on a whole different level.
forresth is offline   Reply With Quote
Old 12-20-2011, 03:50 PM   #8
The Moose is loose.
You make a good point. I don't expect the M18 to come close to standing up to what a corded model would accomplish. I've simlpy never owned a cordless drill with a hammer feature on it so I didn't exactly know what I had. It seems like I'll be set for drilling pilots for tapcons, but not much past that.
What corded model did you go with? Bosch?
Old 12-20-2011, 04:04 PM   #9
In a little over my head
I borrowed a cordless Bosch hammer drill a few years ago, from a friend. That thing would put a hole in concrete like a sharp knife into a filet. When I tried to borrow it again last year, the battery had gone south, and a replacement (obsolete) was as much as he'd paid for the drill. I borrowed a corded drill; he has a really nice boat anchor.
ratherbefishing is offline   Reply With Quote
Old 12-20-2011, 08:45 PM   #10
I've found the little M12 hammer drill to be a great for Tapcons and other small holes. It certainly is faster than a regular drill and a masonry bit. Also seems to make the masonry bits last longer.
Just drilled a couple 2" 5/8" holes for some wedge concrete anchors with the M12. Took about a minute or 2 per hole. Certainly not super speedy but for as often as I (the typical homeowner) drill into concrete, masonry, etc. it works for me. Not sure I could justify a rotary drill (or even rental) for the few holes I drill.
I think if you have expectations that it will fall somewhere between a regular drill + masonry bit at the low end and a rotary drill at the high end you'll be fine. Don't expect it to push out 1/2-3/4 holes and I think you'll be happy no matter what hammer drill you pick.
Old 12-20-2011, 10:40 PM   #11
Ya, a Bosch. I did a write-up on it here not too long ago.
hammer drill vs. rotory hammer, my results.
I was going into 60-90yo concrete with plenty of large chunks of the local granite rocks for filler.
I spent hours with the cordless and basically got half of my hole half way. The rotary hammer zipped 'em all in a matter of minutes with a whole lot effort on my part too, and with much less bit wear on cheaper bits compared to what I picked up for the hammer drill.
Old 12-21-2011, 04:11 AM   #12
The Moose is loose.
That would be about what I'd expect with a Bosch.
Old 12-23-2011, 10:40 AM   #13
Concrete & Masonry
I've got a few of the M18 hammer drills with the XC batterys. I don't think you'll be let down with them at all if you're mainly using it for Tapcons. If you were planning on drilling 1/2" holes on a regular basis it would be a different story, but for 1/4" holes and under, it's not worth buying a corded hammer-drill IMO.
jomama45 is offline   Reply With Quote
Old 12-23-2011, 01:24 PM   #14
but if that is all you are doing, a regular drill is more than enough and has less to break and go wrong with it.
Old 12-24-2011, 12:46 AM   #15
The Moose is loose.
Before I got the M18 combo kit I have now I had the Milwaukee M18 drill/driver without the hammer function and it would not drill a 5/32" pilot into my slab at my house. That was with fresh bits and battery.
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 02:34 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 07:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 10:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
