-   Tools (http://www.diychatroom.com/f29/)
-   -   Milwaukee cordless hammer drill - keyless chuck screw stripped (http://www.diychatroom.com/f29/milwaukee-cordless-hammer-drill-keyless-chuck-screw-stripped-156232/)
eclark 09-08-2012 05:46 PM
So I got a hand-me down milwaukee cordless hammer drill that worked great till the keyless chuck froze up. No problem, I figured just replace the chuck. I got the chuck open with a couple of pipe wrenches and put an allen key in there only to find out that the screw that holds the chuck to the motor shaft is stripped. Any ideas about how to remove?
TIA!
joecaption 09-08-2012 08:21 PM
Most likly because someone did not know it was a left hand thread.
Do you have a new screw for it yet. Most likly a hardware store of box store is not going to carry a LH flat head cap screw.
If your feeling lucky clamp the chuck in a vise and use a 1/4" cobalt right hand drill bit. A reguler dill will not work.
It will do one of two things, catch and unscrew it, or cut off the head so the chuck will come off and the screw will then be loose enough to take out with a pair of needle nose plyers.
eclark 09-09-2012 12:57 PM
I don't have a replacement screw for it yet but figured I'd be able to find one somewhere once I know what size it is. I'll have to buy a cobalt bit if that's really the only thing that will work. Just wanted to see if anyone had ever run up against this before. Thanks Joe
jomama45 09-10-2012 11:01 PM
I've had this issue a few times, as I have/had quite a few of these. As I recall, they were a metric left-handed cap screw, which was hard to find in a pinch. Pretty sure I ran the chuck on as tight as I could by hand and put a "gob" of weld in as far as I could reach with the nozzle of the welder...........:thumbsup:
eclark 09-11-2012 12:38 PM
Sounds like I need to buy a welder to fix my drill lol. Good suggestion though. I'll have to call in a favor if it come down to that. If the screw isn't still available from milwaukee does anyone have any other source ideas?
joecaption 09-11-2012 12:46 PM
Any place that repairs hand tools will have that screw.
I would never use a welder inside a chuck. One weld splatter and the whole thing is trash.
