Milwaukee 2602 Hammer Drill Specs Change? - Tools - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 08:50 PM   #1
I went to buy a 2602 Hammer drill today, and because there was so many versions/packaging, I payed attention to what was in the box. The biggest thing was the low range rpm went from 450 to 550 and the torque is now 525 where it used to be 550. I confirmed this with the website, called Milwaukee myself to ask why, and the techs were not working until after New Years to answer my question....funny, I thought Chinese New Years was no for a while! (LOL) The biggest dissappoint was that I testsed out a few of them in store, and all of them had from very bad to slightly a little chuck wobble! (I also post on amazon.com about this)
Does anyone else have this chuck wobble prob, or know why the spec change?
gvales is offline   Reply With Quote
Old 12-30-2011, 08:57 PM   #2
The Moose is loose.
MooseWoodworks's Avatar
Mine has a slight, and I stress slight, chuck wobble to it. It is nothing that is going to affect the quality of work that I do. Unless of course it gets worse.
MooseWoodworks is offline   Reply With Quote
Old 01-01-2012, 12:45 AM   #3
Rewards Points: 79
My guess would be it's the batteries it comes with. I bet the lower torque is on the compact batteries vs the full size batteries. If you look at the later version's manual here, http://www.milwaukeetool.com/CMS/Dia...-14-2595d5.pdf there's a note about the 550 in-lbs being made only with the bigger batteries.
What batteries came in the kit?
itguy08 is offline   Reply With Quote
Old 01-01-2012, 07:13 AM   #4
I have the full sized batteries. If you go to Milwaukee's site, you can see that the 2602 hammerdrill is listed as a new product with the different specs.
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Is my new hammer drill broken? darsunt Tools 13 09-16-2009 09:53 PM
hammer drill vs. drill/driver wombosi Tools 10 05-12-2008 09:40 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
