Method For Precision Hammerdrilling? - Tools - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 08:35 PM   #1
Rewards Points: 14
method for precision hammerdrilling?
I was just wondering if anyone had some tips on drilling precise holes into concrete. I mark dead centre where i need to drill but the drill bit doesnt seem to stay on my point.
thefatpigeon is offline   Reply With Quote
Old 04-13-2010, 10:04 PM   #2
Civil Engineer
Rewards Points: 4,938
The problem with concrete drilling is that the bit is often not too sharp, so it wanders. Start with a new, carbide tipped bit, use a hammer drill, and use a center punch to start a small hole. Should work better. But don't expect perfection, unfortunately the bit will walk a bit, especially if you hit a hard piece of stone in the concrete.
For real precision work, use a 38 ramset or a 22 ramset to install pins.
Old 04-13-2010, 10:15 PM   #3
Rewards Points: 14
its a 7/16 inch hole for a 3/8 inch drop in anchor in a concrete housekeeping pad. the fixture has for holes in it. 3 lined up nice but the fourth needed to be reamed out with a step bit to allow the bolt to line up. doesn't look very nice. I will try making a pilot hole of sorts using the punch. used to hold a 112.5 kva transformer so using ramset wont work.
Old 04-13-2010, 10:37 PM   #4
If I wanted a precision located hole drilled in concrete, I would first drill a smaller hole in a piece of 1/4 metal and secure it to the concrete by standing on it. Use this as a pilot guide.
I have done this many times and if I want to be "dead on" I drill the desired finish hole in the metal and finish drilling.
Securing to prevent movement is sometimes the problem.
Giles is offline   Reply With Quote
The Following User Says Thank You to Giles For This Useful Post:
PaliBob (04-13-2010)
Old 04-13-2010, 10:55 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Thanks for the hole in a plate tip
sounds good
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-14-2010, 05:54 PM   #6
Rewards Points: 14
ya i was thinking on making a template too since i have 7 more to install.
Proper method for well pump wires coming through wall theedudenator Electrical 3 02-10-2010 11:10 PM
Cement Board -- Correct Install Method? unionmaid Kitchen & Bath Remodeling 9 01-09-2010 10:04 AM
Best Method To Sleeve Slab Penetrations jrepp Building & Construction 4 12-28-2007 05:02 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 06:18 AM
Over 8 Foot Wall - Method of Applying Sheathing... MoparAutoworks Building & Construction 14 08-20-2006 07:38 PM
