Metal Saw Replacable Blades Which - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 08:38 AM   #16
the Musigician
DangerMouse's Avatar
Since most of the nails are on the ends, even a saber saw with a metal blade could work, no?
DM
Old 08-05-2010, 08:45 AM   #17
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Here's one for recip blades
if you don't want to use hacksaw blades, here's one for sawzall blades
http://www.amazon.com/MK-Morse-JSHRB...1015834&sr=1-1
http://www.amazon.com/Milwaukee-48-0...ref=pd_cp_hi_0
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-05-2010, 07:58 PM   #18
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
To me I think the big problem in using a hacksaw blade (or a Sawzall blade) is in forcing the blade between the pallet frame and the salvaged board without unnecessarily scarring the board. A hack saw blade holder by itself IMO would require a lot of extra effort to overcome the tight bond to the pallet frame.
I would use a cheapo circular saw to make cross cuts to cut away the frame around the nails. It would take multiple cuts through the 2x4 pallet frame to isolate the nails but a circular saw would take care of most of the hard work.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-05-2010, 08:13 PM   #19
Rewards Points: 81
It's going to be crazy slow to go at that with a hacksaw. What kind of wood in the pallets? If it's breaking up when you use a crowbar, it kind of begs the question: is it worth recovering?
If you do settle on cutting the nails, definitely get a reciprocating saw (Sawzall). It's a $20-$30 deal at Harbor Freight. We're talking about saving you a lot of hours.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 08-05-2010, 08:44 PM   #20
Tool Geek
PaliBob's Avatar
HF has one with a rotating on sale for $25
Also blades
metal saw replacable blades which-hf-recip-saws.jpg   metal saw replacable blades which-hf-recip-blades.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-06-2010, 02:26 AM   #21
Hmmm decisions decisions.
Having trouble finding UK suppliers or UK ebay/amazon.
What I might do is
I have a cheap general purpose saw.
Use that till it gives out.
Then chop the blade off leaving a few inches.
Drill a hole and mount a reciprocating blade with a nice big bolt.
Also there seems to be some sort of "notch" on the blades. Once mounted I might mark through this at various angles and drill holes and insert a small bolt to stabilize things.
Does this sound like a plan ?
Thanks Compo
Compo is offline   Reply With Quote
Old 08-06-2010, 04:04 AM   #22
Tool Geek
PaliBob's Avatar
Compo, Was the name of my favorite character along with Nora Batty on the old BBC TV show Last of the Summer Wine - Compo's box
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-06-2010, 05:22 AM   #23
Re Compo , yes I am a gardener and joined a garden forum. I used Compo on that and retained it .
The recycled pallets are used for raised beds !
Compo
Old 08-06-2010, 08:53 AM   #24
I have opted for
http://cgi.ebay.co.uk/ws/eBayISAPI.d...EOIBSA:GB:1123
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230349483038
Will let you know how well they work !
Compo
Old 08-06-2010, 09:08 AM   #25
Electrician
Proby's Avatar
I don't think it's going to work that great. 6 teeth per inch isn't that good for metal, especially when cutting by hand. That's more of a universal metal and wood blade.
I think you are going to be there for hours upon hours upon hours, killing yourself. A $30 sawzall would do that work in seconds.
Either way, good luck!
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 09:32 AM   #26
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I was thinking the exact same thing. It should work fine on the stringers, but I can't see him possible getting anywhere near enough strokes-per-minute to get this coarse blade through a standard or hardened nail. Hopefully he's not cutting the nails ( don't think he ever said for sure)
He's gonna have forearms like Popeye by the time he gets these planters built.
Compo-- Best of luck, let us know how you make out!!
Old 08-06-2010, 10:12 AM   #27
Electrician
Proby's Avatar
I think his intentions are to cut the nails:
Originally Posted by Compo View Post
I want a saw that can cut through the nails between the planks.
So eventually I came to the conclusion that to saw between the planks and cutting the nails is best for time/effort/damaged planks.
Old 08-06-2010, 12:36 PM   #28
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
WOW, i totally missed that post. but i read the one directly after it. Strange....
Old 08-06-2010, 06:43 PM   #29
DIY staff
Rewards Points: 7,174
Old wood salvagers often use a home made 'hole saw' to cut around the nail--leaving only a hole.
If you have access to some old push rods from a large engine---cut it in half--file or grind saw teeth on one end---chuck that in a drill. Center it over the nail and drill!
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 09:32 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
