Metal Saw Replacable Blades Which - Tools - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 07:16 AM   #1
metal saw replacable blades which
I want to disassemble some pallets.
I want a saw that can cut through the nails between the planks.
A hacksaw won't do as it won't fit.
I want a hand saw.
There are a number of general purpose saws on the market
Questions
1) Are the differing manufactures blades interchangeable,
2) Can you get handles for the power saw blades.
In conclusion can anyone recommend a metal cutting hand saw ?
Compo
Compo is offline   Reply With Quote
Old 08-04-2010, 07:22 AM   #2
the Musigician
DangerMouse's Avatar
They make holders for hacksaw blades so you can use the end of the blades as you need to, but a sawzall with a metal blade would be a helluva lot faster and easier.
DM
Old 08-04-2010, 04:58 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
a crow bar would be easier than a handsaw. i'd rent/borrow/buy a circ saw or recip or even a chainsaw if it was me.
if you insist on doing it with a hand saw, just get a couple cheap all purpose "tool box saws". the blades aren't replaceable, but for $10 or so a piece you can toss them if you wear them out. they do make a handle for a hacksaw blade, without a frame, but the teeth of a hacksaw blade are way too fine for cutting pallets
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-04-2010, 09:01 PM   #4
Handyman
Rewards Points: 512
Pallets..another joke, right???
canadaclub is offline   Reply With Quote
Old 08-04-2010, 09:05 PM   #5
the Musigician
Ya never know....
DM
Old 08-04-2010, 09:13 PM   #6
Electrician
Proby's Avatar
He doesn't want to cut pallets, he wants to cut the nails between the planks.
This tool holds sawzall blades:
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-04-2010, 09:23 PM   #7
I've seen some pallets that were built with some very nice Oak
Plenty of people take them apart & make furniture out of them
I'd us a sawzall myself
This chair was made from a pallet
Old 08-04-2010, 09:35 PM   #8
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
I would rather be water-boarded than use a hack saw. Buy a reciprocating saw (sawzall). You'll use it again some day. If you want a cheap one, harbor freight (cough, vomit, swallow) has them for $30. If you want a good one, get a DeWalt from Lowes for around $100.
WirelessG is offline   Reply With Quote
Old 08-05-2010, 06:31 AM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
that's why i said a crowbar instead of hacksaw. just pull up the stringers a little, then pull the nails. Faster and easier than hacking nails
Old 08-05-2010, 06:49 AM   #10
DIY staff
Rewards Points: 7,174
Pallet nails are usually hardened twisted nails---not easy to cut or pull---
Old 08-05-2010, 06:54 AM   #11
the Musigician
Well, a sawzall would still breeze through them, but I gotta agree with Chips.... use a crowbar!
Unless there's a REASON for wanting to keep the nail heads in your boards?
DM
Old 08-05-2010, 07:51 AM   #12
I have looked into many ways of dismantling pallets.
Originally I used a crow bar but most pallets use ring shank nails and are virtually impossible to get out, the planks usually split and nails pull though.
It is possible to prize the planks up a bit and try and get a crowbar onto the nails.
Often the head just pulls off and it's very time consuming.
So eventually I came to the conclusion that to saw between the planks and cutting the nails is best for time/effort/damaged planks.
Old 08-05-2010, 07:59 AM   #13
The Lenox handle looks promising, any UK suppliers?
Can't see it on ebay or amazon.
Note: Recycling pallets obviously means I am a scrooge, so minimal price is best !
Old 08-05-2010, 08:20 AM   #14
Electrician
Proby's Avatar
You'll loose money on the time wasted trying to cut the nails by hand, vs. spending $69.95 on a sawzall.
Old 08-05-2010, 09:33 AM   #15
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
There is a hacksaw blade holder that's much cheaper than the lennox one. Try searching for"mini hacksaw" or " Bronco Hacksaw". They call it a mini, but takes standard blades
found one that should fit your Scrooge Budget. Happy Hacking
http://cgi.ebay.com/Bronco-Mini-Hack...item35a5cc2ed5
http://www.amazon.com/Stanley-20-807.../dp/B0009VUL18
Clearcoating a Stripped Vintage Ferrous Metal Medicine Cabinet? Lovegasoline Painting 15 08-31-2013 10:32 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
