Is It Me, Or My Drill? - Tools - DIY Chatroom Home Improvement Forum
Old 07-11-2015, 09:58 AM   #1
Rewards Points: 14
Is it me, or my drill?
I am framing a basement with metal studs (25 gauge). I chose metal because I have to work alone, and have no experience with a saw. Thus far, I have all the metal studs plum, and the frame of the room is what I want.
The issue I have is that when I go to hang the 1/2 inch drywall, with fine thread drywall screws, I cannot drill the screws into the metal studs.
I'm wondering if my Craftsman 9.6v cordless drill is just not powerful enough for this. I purchased new screw bits (#2 phillips) for the job. I was able to drill the #8 1/2 inch pan head self-tapping fasteners into the studs with this Craftsman, and it was challenging. But the drywall screws just aren't going through.
I have tried taking some extra bits of dry wall and practicing screwing them into the extra bits of the metal studs, but I couldn't get it in in a way I felt comfortable trying on the real wall.
Thank you for any help you might be able to provide.
jonnyd is offline   Reply With Quote
Old 07-11-2015, 10:04 AM   #2
Rewards Points: 12,858
Pretty wimpy drill for that job.
SO what's it doing? Stalling out, just spinning?
Going to have to push hard to get the screw started.
Old 07-11-2015, 10:10 AM   #3
Rewards Points: 14
It's just hitting the metal and not going in, spinning on the surface. When I fastened the studs with the #8s, I had to push hard to get them in, but they went in.
I am hoping that it's the drill, so that I can just rent a more powerful one.
Old 07-11-2015, 10:26 AM   #4
No way would I rent a drill, just go buy one.
I use my Ryobi impact driver far more then my drills.
It will drive screws, nuts, bolts, drill holes far faster then a drill.
Only time I use a drill any more is if I'm drilling metal or concrete.
Sound like your just not pushing hard enough.
http://www.homedepot.com/p/Ryobi-18-...P898/205308754
Old 07-11-2015, 12:25 PM   #5
Gymschu's Avatar
Rewards Points: 232
I know a few times when I have worked with metal studs I have had to PRE-DRILL the holes through the drywall and through the studs. Just be sure your pre-drilled hole is SMALLER than the size of your screws. Of course, a more powerful drill will do the trick as well. Anyone in your neighborhood willing to loan you an 18v or 20volt?
Giving us your general location helps us better help you!
Old 07-11-2015, 12:36 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 828
Your not using the right screws. Standard drywall screws are not going to go into metal studs without a pilot hole.
You need to use self taping screws made for drywall and metal studs.
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
Gymschu (07-11-2015), oh'mike (07-11-2015)
Old 07-11-2015, 01:09 PM   #7
Rewards Points: 144
ddawg16 has it right.Regular fine thread drywalls screws are not made for going into metal.And either way,as Joe suggested, the drill is pretty wimpy for the job.
mako1 is offline   Reply With Quote
Old 07-11-2015, 01:20 PM   #8
Rewards Points: 1,002
Actually, they are made specifically for metal studs
Anti-wingnut is offline   Reply With Quote
The Following 2 Users Say Thank You to Anti-wingnut For This Useful Post:
MTN REMODEL LLC (07-13-2015), ToolSeeker (07-15-2015)
Old 07-11-2015, 01:26 PM   #9
Rewards Points: 144
Maybe I should have been more specific.There are fine thread drywall screws made for metal that are self tapping.Not all fine thread drywall screws are self tapping.
Old 07-11-2015, 01:31 PM   #10
Are you talking about pointers or self drillers? You don't use self drillers on 25ga
Old 07-11-2015, 01:34 PM   #11
The OP's drill motor is probably too slow
MTN REMODEL LLC (07-13-2015), oh'mike (07-11-2015)
Old 07-11-2015, 01:34 PM   #12
Rewards Points: 144
I was speaking specifically to the ops problem using his 9.6 V Craftsman drill.This is a DIY forum and not everyone wants to go spend $200 on a new driver for a small DIY project.I was giving him an option that would work for him.
Old 07-11-2015, 01:50 PM   #13
The title of this thread is "is it me, or my drill?"
I was answering that
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Old 07-11-2015, 02:16 PM   #14
Rewards Points: 144
Of course it's his drill.I think joe has answered that question a few posts back.I was trying to give him some options with his present drill until you came along and wanting to argue over the details.I am a pro and belong to several pro forums.This is a diy forum as you know and most of these guys want the cheapest and easiest fix.
I thought the info I gave was helpful to his situation.Contradicting me is not.
Old 07-11-2015, 02:29 PM   #15
Thanks for the CV. You gave him several answers about fine thread drywall screws which were in error. You may not like people contradicting your errors, but that doesn't concern me.
The OP should make sure his direction of travel is correct
Tags
basement , drill , drywall , metal studs
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
