Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-17-2010, 07:54 AM   #16
May I ask about wheel Bearings?
found the steel rod for under $5. now, the question is do i want "hot rolled" or "cold rolled" steel?
I'll want it inflexible but also want the ability to cut it down w/ a hack saw and drill a hole for the cotter pins.
and so far, i've not had luck on locating "Tee Bolts" big enough to support 1/2" rod.
rosco is offline   Reply With Quote
Old 06-17-2010, 08:45 AM   #17
Super Moderator
Either will work--Cold rolled is stronger. Will be a bit harder to cut and drill. Less likely to bend under the weight of the chicken coop.
Old 06-17-2010, 07:28 PM   #18
i've got the rod in place. I'll keep an eye out for "Tee Nuts" that are slightly larger than the 1/2" cold rolled steel bar.
May I ask about wheel Bearings?-dscf2877.jpgMay I ask about wheel Bearings?-dscf2876.jpg
I"ll keep it off the wheels until I put them in place. But for now, i can move it easily!
Thanks!
New inducer motor but wheel hits housing mrgoodwx HVAC 6 02-09-2010 09:35 PM
PAYNE PY1PNB060115AAAA Inducer Wheel Failure. Help please! Coldvol HVAC 1 12-03-2009 07:13 PM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 09:14 PM
Toro 7/24 Snowblower - friction wheel Ottawa Landscaping & Lawn Care 1 02-02-2009 09:01 AM
