May I Ask About Wheel Bearings? - Tools - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 04:18 PM   #1
Rewards Points: 150
May I ask about wheel Bearings?
i'd like to have these wheels suport and function like those on a lawn mower or yard fertilizer. these certainly work, but not very well and end up damaging the wood frame.
this is the chicken "tractor" they are used to move - http://www.backyardchickens.com/web/...ractor-cooprun. no ideas on how to affix wheels have come yet.
any ideas? i don't have a welder.
let me know if this post belongs in another forum...
rosco is offline   Reply With Quote
Old 06-11-2010, 07:58 PM   #2
DIY staff
Rewards Points: 7,174
You need a straight Axel-The bolts move in the wood and will soon rub the side of the frame.
Your hardware store will have 1/2" steel rod in lengths long enough to go all the way across the frame and stick out each side long enough to put a stack of washers--the wheels--another washer--and a cotter pin.
The only tool you need is a hack saw and a drill(to make the hole for the cotter pins.) There are screw on caps made to avoid the cotter pin--however I find they fail a lot.
Better wheels--with bearings-- may make your cart more usable if it weighs a lot--Harbor Freight is one source.---Mike---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
rosco (06-12-2010), Willie T (06-11-2010)
Old 06-12-2010, 01:22 PM   #3
Use Tee Nuts
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
rosco (06-12-2010)
Old 06-12-2010, 01:46 PM   #4
(the original)
Rewards Points: 756
Very good advice here. I'd also move the cross brace back to where the wheels are now and move the wheels out to the brace position so they extend beyond the frame ends, then cut a little off the bottom corners of the frame at a 45 degree angle. As it is right now, you don't have any ground clearance when you tilt it up to move it.
ratherbefishin' is offline   Reply With Quote
The Following 2 Users Say Thank You to ratherbefishin' For This Useful Post:
oh'mike (06-12-2010), rosco (06-12-2010)
Old 06-12-2010, 05:30 PM   #5
Rewards Points: 150
Originally Posted by hayewe farm View Post
Use Tee Nuts
Thanks! where would i get these?
i'll look at switching the wheels and cross-brace. possibly cutting the frame back. i'm afraid any more screws or holes will cause the frame to crack badly. it is old wood.
Thanks all!
Old 06-12-2010, 07:26 PM   #6
Just about any big box store or decent hardware store.
Old 06-12-2010, 08:34 PM   #7
Rewards Points: 150
Box store? as in a place that sells cardboard boxes? Home Depot and Lowes have shut down most all locally owned hardware stores.
do the "Tee Nuts" have threads? it seems if they didn't i could use "hayewe farms" and "oh'mike's" ideas together.
Old 06-13-2010, 11:42 AM   #8
Big Box store means Lowes and HD among others.
Yes the tee nuts are threaded, If you use them on the outside of the board and the nut and washer on the inside then the
wheel will be the only thing turning so the threads won't eat into the wood.
Old 06-13-2010, 03:43 PM   #9
Rewards Points: 150
Question
do you mean a threaded metal rod? i thought you'd suggested a rod w/o threads and am wondering about the "nut."
THX!
Old 06-13-2010, 04:41 PM   #10
I'm talking about what you have now. The wood gets torn up by the threads on the rod. The Tee Nuts will prevent the threads from being in contact with the wood. By reinstalling the nut and washer on the inside you will lock the units together so only the wheel turns.
If you are planning on going to a steel rod across instead, you should install sleeves in the wood to prevent damage.
Old 06-13-2010, 07:35 PM   #11
Rewards Points: 150
Right. the objective is to minimize wobbling of the wheels and maintain what integrity is left in the wood frame. What is recommended? a steel rod across w/ sleeves or the Tee Nuts with bolts?
sorry about the confusion. i'm prone to it
Old 06-13-2010, 07:55 PM   #12
Either will work, it's up to you.
Old 06-13-2010, 08:33 PM   #13
Rewards Points: 150
What will be the secret to minimize wobbling?
Old 06-14-2010, 09:54 AM   #14
DIY staff
A solid axle like I mentioned will not wobble--this could also be attached to the bottom of the 2x4 frame
using metal pipe fasteners--thus giving you a bit more ground clearance.
Take a look a a garden cart (like garden Way) these use a straight axle and wheels --with a ply-wood box on top--Holds a lot of weight--no wobble-
---Mike--
Old 06-15-2010, 04:20 AM   #15
Rewards Points: 150
---Mike--
ah, the problem is that the 1/2"x4" frame must sit on the ground. i love the steel bar idea! finding one is a bit difficult. it is as if no one has ever heard of such a thing.
i think as soon as i find a 5' steel rod i'll use it with cotter pins. the design i dreamed up was to have the wheels detach. i only move the thing once a week. Popping wheels onto the bar, in only a few seconds, would afford the chickens much comfort.
To explain: there is 4"x4" wire on the bottom of the chicken tractor and the chickens already hate the wire on the ground. they'd stop laying if i lifted the wire off the ground.
New inducer motor but wheel hits housing mrgoodwx HVAC 6 02-09-2010 09:35 PM
PAYNE PY1PNB060115AAAA Inducer Wheel Failure. Help please! Coldvol HVAC 1 12-03-2009 07:13 PM
comfortmaker rpj2 blower wheel problems nuclearjesus HVAC 3 11-22-2009 09:14 PM
Toro 7/24 Snowblower - friction wheel Ottawa Landscaping & Lawn Care 1 02-02-2009 09:01 AM
