Mastercraft Thickness Planer Prob - Tools - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 09:28 PM   #1
mastercraft thickness planer prob
All of a sudden my planer quit on me. I had heard the odd clunking noise a few times lately but it still worked fine. I used a multi meter to test the switch and its ok I also checked the brushes and they look fine too. I tried the reset button but it didn't seem to do anything so I pulled it and tested the continuity between the two connectors. Anyone have any sugestions as to what to do next. Thanks for your help.
beech is offline   Reply With Quote
Old 09-10-2013, 09:37 PM   #2
Rewards Points: 13,270
Checked to see if a breaker tripped?
Might help if you posted a model #.
Electrical problems are not going to make a clunking noise. Time to find out what's causing it. If something locked up it's not going to run.
Old 09-10-2013, 10:02 PM   #3
model number is mastercraft 55-5503.
Old 09-10-2013, 11:01 PM   #4
A keyword search came up with very little.
Looks like the company may be out of business.
Lots of complaints about the belts breaking.
Old 09-11-2013, 09:32 AM   #5
Thanks joe. I'm sure the company is still in business as I spoke to them the other day to get a replacement manual. I'm thinking it must be the switch and I maybe I didnt test it properly. It has 4 wires to it. One white and one black on one side with another black and a green on the other side. I tested continuity between the white and black on the same side and there was continuity with the switch on but no continuity with the switch off. Is this correct. Again thanks for your help.
Old 09-11-2013, 09:50 AM   #6
joed's Avatar
Rewards Points: 11,992
Clunking noise won''t be electrical. With the unit unplugged can you turn the motor by hand?
Company is not out of business. Here is the unit still for sale.
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old 09-11-2013, 10:13 AM   #7
Sorry Joe I rechecked the wiring of the switch.It has a black and a white on one side and two blacks on the other side. I tested continuity with switch on from the white to two other black wires and there was continuity. Anything else I should do.
Yes I can turn the motor by hand and the belt is good
Need to taper the thickness of a 2x8 - How? laportebj Carpentry 7 09-09-2011 07:59 AM
What thickness veneer for pocket door? GarrettP1 Carpentry 3 06-22-2011 10:01 PM
Plywood thickness: asked for 1/2" plywood; hardware delivered 7/16 (.437) thickness) lazzlazz Flooring 7 03-31-2010 12:25 PM
Makita Precision Planer lalkie Tools 2 09-21-2009 09:57 AM
